Crank oil seals
  • mack
    • 2411
    • Ontario, Canada
    Crank oil seals
    Ok guys, who stocks the twp oil seals for the ends of the crankshaft. I've tries nw vintage and CMS and my dealer.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    Looks like the alternator side seal is still available from Yamarobber but the ignition side has been discontinued. Both seals are available in generic form without the raised outer ring.
    • mack
      • 2411
      • Ontario, Canada
      source
      Don't suppose you have a source and number for it would you?
      mack
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      613-398-6186
        Look around and see if you can find these listed somewhere on the net. They're a double lipped seal and I've had good luck with them.
        First one is a 32X45X7 and the other one is a 32X48X8.
        This isn't a bad deal for them on Ebay... Might pick up a couple each in case you mess one up on the install, or just to have as spares. They don't take up much room.
        http://www.ebay.com/itm/32X45X7-TC-M...item2323ea7583
        http://www.ebay.com/itm/32X48X8-TC-M...item2323ea7b1d
        • mack
          • 2411
          • Ontario, Canada
          Thanx Big
          You and I think a like, with my fleet growing you never know when extras will come in handy. As a side note, I made a jug removal tool off your basic design. Very smart idea, worked like a charm. Loved your engine thread too. Unfortunately I didn't see it until this one was already torn apart. Nice camera work.
          mack
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          613-398-6186
            Thanks. Glad it helped someone. I've seen several destroyed cylinders posted over the years.
            • mack
              • 2411
              • Ontario, Canada
              Oil seals
              What about the ones you don't have to split the cases to install. Last xs north rally Andy blew his out and I had to trailer him home. If we'd had one of these handy we could have installed it on the side of the road.
              mack
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              613-398-6186
                Mack, I'm pretty sure that the Yamaha OEM seals are the only ones that have the outer protruding lip where cracking the cases is needed.
