1980 Carbs
    • 8798
    George, no there isn't an o-ring, there is a thin fiber gasket ring under the screw in seat shoulder. They do go bad sometimes and one could be made from gasket paper. Some newer kits have metal rings instead of the fiber ring. Be aware that the thickness of this fiber gasket will affect the float level and will need to be rechecked when replaced.
    • Jay60465
      • Jul 2013
      • 30
      • Westmont, IL
      #62
      carb thread jacking
      The floats are in good shape they were floating nicely in the carb cleaner...lol..also there was no fluid present in the floats after taking off the bowls. I haven't got a chance to get back at the job, because of work. I want to check that gasket overlap for sure.
      80 SG
      • Jay60465
        • Jul 2013
        • 30
        • Westmont, IL
        #63
        Thread Jacking 1980 special Carb Help
        OK i know it has been awhile. Been busy with school and been tinkering here and there with these floats. Still pouring out of the overflow vent like crazy.
        So far I:
        1. Measured the 8 floats to the stock specs...3 and 4 pour.
        2. checked bowl gasket for overlap...good
        3. Bent the float tang more so the floats would close sooner..still floods
        4. changed the needle seat to old ones just in case the new ones were defective....still flooded
        5. I blew into the supply hose by mouth and tested the floats and they open and close by mouth air pressure, as if they were working properly.
        Just a reminder this is a 80 special with 79 carbs with brass floats and threaded pilot screw cover and threaded float needle seat.
        PS: Maybe I bent the float tang the wrong direction...I pushed the tang down closer to the needle valve, with the carbs standing on the diaphragm covers.
        80 SG
          #64
          Are you connecting the fuel to the lower of the two T's or the top? Should be connected to the lower T.
          • Jay60465
            • Jul 2013
            • 30
            • Westmont, IL
            #65
            yes it is connected to the lower fittings
            80 SG
              So far I:
              Can't just bend a float tab to whatever and call it good. Getting it running correct just throwing guesses and no actual measuring of floats WILL get you and the bike nowhere. On top of that, you went the wrong direction with the float. Cooperation as to what we suggest here is needed, or we can be of no help. Important that only ONE change at a time be made and test results before moving on. Your gonna have to remove that carb bank, bowls, and start all over by first putting the new seat needles back in BEFORE float settings are measured and then re-adjusted. FWIW, when you remove those float pins, chuck them up in a drill by there ends. Take a file using the narrow flat end of it up against the base of pin where the stop on it is, spin the drill and lightly file that short larger diameter area so the float pins JUST will slide in and out easily. If not, the next disaster that may follow WILL be a broken float pin post, as you will be removing and installing the floats several times till the MEASURED setting IS correct. The MOST important part of that float setting IS that they ALL need to be exactly the same,....to a T.
              • Jay60465
                • Jul 2013
                • 30
                • Westmont, IL
                #67
                When I rebuilt the carbs i set all eight floats to 25.7mm from the gasket base (no gasket). I will modify the pins the next time thanks for the heads up. So, i guess my next question is:
                If I decrease the float height, will that close the valve quicker? Because I have a height around 28mm right now, and earlier the 25.7mm had flooding results too.
                Again I am not trying to short cut anything, this is a project. I have time to make attempts at several things
                80 SG
                  #68
                  Changing the float heights to something other than stock as an attempt to stop flooding will not help. Set them back to the 25.7 and figure out why the flooding is happening.
                  Is the gasket under the float needle seat there?
                  Is the needle in good condition?
                  Is the spring on the needle pin part still functioning?
                  Is there crap holding the needle open?
                  Are there holes in the floats?
                  Are the float bowl vents clear and open? If you are using the 80 airbox the nipples for the vent lines are on the box but they are not drilled open so it would be like sealing the vents closed.
                  Something is causing them not to seal.
                  • Jay60465
                    • Jul 2013
                    • 30
                    • Westmont, IL
                    #69
                    flooding fun
                    yes I have the gaskets installed along with the seats....this a complete brand new rebuild kit. all new brass and gaskets
                    Needle and seats are new
                    springs on the needles push in and rebound like new
                    there is no crap in the new seats and i cleaned the old ones when testing them
                    The floats floated fine in the carb cleaning solution and pine sol and there is no sound of fluid when i have been taking them out
                    Now good question WHAT are the float bowl vents is that the brass tube in the bowl...or the vent on the face that pees the gas out?
                    80 SG
                      #70
                      Float bowl vent is the upper T between the carbs.
                      • Jay60465
                        • Jul 2013
                        • 30
                        • Westmont, IL
                        #71
                        float flood
                        ok gotcha...I have the float vents hooked up to a open hose.....how can i tell if these vents are blocked? If these vents are blocked can that cause the carbs to flood out that little hole.
                        80 SG
