ok, don't give me too much crap because I already feel like an idiot. I recently swapped tanks with a guy and I kept my lock . When I tried the key after re-assembling it works but the cap doesn't .The tumbler come out but the hook doesn't move. WTH am I doing wrong? Seems like the spring should be moving the catch on the hook.
*&%#$@* lock set
*&%#$@* lock set
Yamaha 80
Suzuki TM 400
Honda CB 400
Yamaha XS650 chopper
Honda 1800 VTX S
Suzuki C-50 Bobber (wifes)
HD Road King Classic
Yamaha XS 1100Tags: None -
Bear - you might try just hitting it with some graphite - maybe it needs something to ease the way for the key to turn it?
The lock should screw in with 2 screws and the lever/latch should be in the down position (i.e. level) when the lock is in the neutral up and down position - and move down (towards you flat) when the key is turned. Is it moving at all?
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
"Not all treasure is silver and gold" -
yep...it turns like it works but the latch doesn't move. Where does that spring go? Damn John I hate to bug you cause you've already been so helpful.Yamaha 80
Suzuki TM 400
Honda CB 400
Honda 1800 VTX S
Yamaha XS 1100Comment
Pics in this thread may help some, check the last picture...
☮Comment
The problem may be that he's trying to put a lock from a standard tank into the cap of a special tank.
I don't know that it makes a difference but the caps are different.
Theodore RooseveltComment
I have swapped those back and forth greg no problem....
"Not all treasure is silver and gold"Comment
alright I got it. I had to file the tumbler slightly to let the pin on the lock grab it better was all it was. Thanks everyone for the help.
Yamaha 80
Suzuki TM 400
Honda CB 400
Honda 1800 VTX S
check your damn PMs Bear....
Ummm........nevermind.....Greg
