*&%#$@* lock set
  • PapaBear1950
    • Sep 2012
    • 36
    • Wichita, KS.
    *&%#$@* lock set
    ok, don't give me too much crap because I already feel like an idiot. I recently swapped tanks with a guy and I kept my lock . When I tried the key after re-assembling it works but the cap doesn't .The tumbler come out but the hook doesn't move. WTH am I doing wrong? Seems like the spring should be moving the catch on the hook.
    Yamaha 80
    Suzuki TM 400
    Honda CB 400
    Yamaha XS650 chopper
    Honda 1800 VTX S
    Suzuki C-50 Bobber (wifes)
    HD Road King Classic
    Yamaha XS 1100
  • jwhughes3
    • 2798
    • Home of the Alamo
    Bear - you might try just hitting it with some graphite - maybe it needs something to ease the way for the key to turn it?
    The lock should screw in with 2 screws and the lever/latch should be in the down position (i.e. level) when the lock is in the neutral up and down position - and move down (towards you flat) when the key is turned. Is it moving at all?
    John
    '81 XS1100H - "Enterprise"
    • PapaBear1950
      • Sep 2012
      • 36
      • Wichita, KS.
      yep...it turns like it works but the latch doesn't move. Where does that spring go? Damn John I hate to bug you cause you've already been so helpful.
      Yamaha 80
      Suzuki TM 400
      Honda CB 400
      Honda 1800 VTX S
      Yamaha XS 1100
        Pics in this thread may help some, check the last picture...
          The problem may be that he's trying to put a lock from a standard tank into the cap of a special tank.
          I don't know that it makes a difference but the caps are different.
            Doesn't make a difference.
            • jwhughes3
              • 2798
              • Home of the Alamo
              I have swapped those back and forth greg no problem....
              John
              • PapaBear1950
                • Sep 2012
                • 36
                • Wichita, KS.
                alright I got it. I had to file the tumbler slightly to let the pin on the lock grab it better was all it was. Thanks everyone for the help.
                Yamaha 80
                Suzuki TM 400
                Honda CB 400
                Honda 1800 VTX S
                Yamaha XS 1100
                  check your damn PMs Bear....
                  Ummm........nevermind.....
