shorter fenders for an 80' eleven.
  • Yard Dogg
    • Mar 2010
    • 884
    • Tri-Cities, Wa
    Oh I saw the two different starter gears. The one in question was the 86' 1100 with the newer style gear. It was totally hammered. The problem, was the teeth on the starter gear did not engage all the way with the flywheel. So the teeth were totally ate up. I think the cause of it was a weak starter motor. It wasn't throwing the gear out strongly enough. When you install the gear, make sure you grease anything that will help the starter throw the bendix out further so you don't have the same problem. If your starter motor sounds rough or weak, rebuild it or get a new one. Those damned gears are expensive.
      • 2078
      Originally posted by new model army
      Mostly cosmetic inquiries from me today.
      What options are out there concerning shorter back fenders along with smaller tail lights for an 80' xs standard.
      thanks,
      Mark
      Back to the regular scheduled program
      Here is a link to decently priced accessories for ya.
      ( where I got my cateye tailight from)
      • Spags
        • 6
        • Daytona, Fl.
        Originally posted by xs11lover
        That is an 80 xs11 special fender moved front...not cut.
        When you say "moved front" do you mean you just rotated the rear fender forward and made new mounting holes? or is this somehow the front fender on the rear?
        I apologize for the noob question.
        80 XS11
        • xs11lover
          • 1433
          • Montoursville Pa
          Rear fender moved front
          I took a rear fender and moved it forward. I cut the frame...stuffed the ends of an old sissy bar into the end of the frame...mounted the fender to the sissy bar and bolted it all down.
          Maybe this pic will help more.
          79 XS11 Special (Lazarus)
          79 DT 100
            • 5061
            Well, it looks like it is functional and it looks pretty good.
            • Spags
              • 6
              • Daytona, Fl.
              Ah ok I see now. It's hard to tell from the picture but did you end up having to cut any off the top/forward section of the fender ?
              80 XS11
              • xs11lover
                • 1433
                • Montoursville Pa
                The only cutting was on the plastic inner fender and the frame.
                79 DT 100
                  I assume you did move the TCI down more behind the battery box?
                  • xs11lover
                    • 1433
                    • Montoursville Pa
                    I started out thinking if I used a special inner fender I could still mount it to the plastic inner fender........but ended up putting the tci in the glove box.
                    79 DT 100
                    • Cobia
                      • Jul 2007
                      • 1587
                      • Palm Beach County, Fl
                      And look at all those tanks hanging from the rafters !!!
                      1980G Standard, Restored
                      Kerker 4 - 1
                      850 Rear End Mod
                      Automatic CCT
                      1980GH Special, Restored
                      '82 XJ1100 (Sold)
                      • Yard Dogg
                        • Mar 2010
                        • 884
                        • Tri-Cities, Wa
                        I wish my bike were that purdy! It's beautiful.
