Oh I saw the two different starter gears. The one in question was the 86' 1100 with the newer style gear. It was totally hammered. The problem, was the teeth on the starter gear did not engage all the way with the flywheel. So the teeth were totally ate up. I think the cause of it was a weak starter motor. It wasn't throwing the gear out strongly enough. When you install the gear, make sure you grease anything that will help the starter throw the bendix out further so you don't have the same problem. If your starter motor sounds rough or weak, rebuild it or get a new one. Those damned gears are expensive.
shorter fenders for an 80' eleven.
Pics: http://s1236.photobucket.com/user/ya...?sort=6&page=1 -
Back to the regular scheduled program
Here is a link to decently priced accessories for ya.
( where I got my cateye tailight from)
http://www.ebay.com/sch/thealphamoto...id=p4340.l25621980 XS1100G "Dolly G" Full Dresser (with a coat of many colors
Rear fender moved front
I took a rear fender and moved it forward. I cut the frame...stuffed the ends of an old sissy bar into the end of the frame...mounted the fender to the sissy bar and bolted it all down.
Maybe this pic will help more.
79 XS11 Special (Lazarus)
79 DT 100Comment
I assume you did move the TCI down more behind the battery box?Life is what happens while your planning everything else!
78 XS750Comment
I started out thinking if I used a special inner fender I could still mount it to the plastic inner fender........but ended up putting the tci in the glove box.79 XS11 Special (Lazarus)
79 DT 100Comment
And look at all those tanks hanging from the rafters !!!1980G Standard, Restored
Kerker 4 - 1
850 Rear End Mod
Automatic CCT
1980GH Special, Restored
'82 XJ1100 (Sold)
Automatic CCT, RC Engineering 4 X 1 Exhaust, K&N Pods, #50 Pilot Jets, YICS Eliminator. Sorely missed.Comment
I wish my bike were that purdy! It's beautiful."The Hooligan" XJ1100, Virago Gauge Pods, Screaming Eagle Mufflers, K&N Filter, hand made rear fender, side covers, and solo seat, round bar conversion, small headlight, tail light, and cat eye turn signals, chip fuses, rewired the right way.
Pics: http://s1236.photobucket.com/user/ya...?sort=6&page=1Comment
