What is the part # for that coil TC, I put xs1100 in search on the dynatek site and got nothing.
Spark plug cap resister source?
Hey Bear,
You just have to know the TYPE of coil you want, a dual output/dual tower with 12v primary and ~3 ohms rating. The DC-1 model is what is used. You'll need to get a separate wire/cap set!
For the older XS11's, 78-80, folks just bypass the ballast resistor so that the new coils get 12 volts all the time, the TCI will still see 3 ohms on the trigger side so it will be happy.
T.C.T. C. Gresham
Hey Bear,
Sorry, that's DC1-1 dual output, 3 ohm type! The DynaTek website SUCKS!
See following AMAZON ad:
http://www.amazon.com/Dynatek-Coil-1...rds=dyna+dc1-1
Ebay:
http://www.ebay.com/itm/Dynatek-Igni...-/140740594590
Example of plug wire kit, note the shape of end for coil.
http://www.ebay.com/itm/UNIVERSAL-SP...-/170928199069
Not recommending seller, just has decent description, HOWEVER, these kits do NOT come with all necessary hardware to install...you need to acquire a separate Plug Wire/Cap kit....they use a large round metal compression type clip for the end that fits into the coil body, the wires can NOT just be threaded onto the coils!
T.C.T. C. Gresham
The caps you need Bear are 2- XB05F, and 2- LB05F.
http://www.motorcycle-superstore.com...T.ac=SLIsearchGreg
Thanks everyone for the help. My head is about to explode with all of this stuff.I feel like a dummy.
$125 seems like a hell of a lot of money for a coil? I get that you need a dependable one but I'm building this on my Social Security check...LOL
Greg, I already have the LDO5f but 2 and 3 are XDO5FLast edited by PapaBear1950; 10-23-2012, 09:55 PM.Yamaha 80
Suzuki TM 400
Honda CB 400
Yamaha XS650 chopper
Honda 1800 VTX S
Suzuki C-50 Bobber (wifes)
HD Road King Classic
Yamaha XS 1100
Originally posted by PapaBear1950 View Post$125 seems like a hell of a lot of money for a coil? I get that you need a dependable one but I'm building this on my Social Security check...LOLFast, Cheap, Reliable... Pick any two
Greg, I already have the LDO5f but 2 and 3 are XDO5FGreg
Hey Bear,
Others have gotten Coils from a used Honda VF1000, they are dual towered and 3 ohms. See this ebay link:
http://www.ebay.com/itm/HONDA-VF1000...-/271064326173
I don't know the stats on their output power, but are recommended by the fellows across the pond( UK ) as well as members on this site!
The coils look like they use a special screw on wire cap/seal, and I think the wire fits into the coil ON/OVER a screw stub or such down inside the tower, but others can confirm this info....so you may need to look at getting a set of solid core wires that will fit the Honda coils?!
T.C.T. C. Gresham
