Spark plug cap resister source?
  • PapaBear1950
    • Sep 2012
    • 36
    • Wichita, KS.
    What is the part # for that coil TC, I put xs1100 in search on the dynatek site and got nothing.
    Yamaha 80
    Suzuki TM 400
    Honda CB 400
    Yamaha XS650 chopper
    Honda 1800 VTX S
    Suzuki C-50 Bobber (wifes)
    HD Road King Classic
    Yamaha XS 1100
      Hey Bear,
      You just have to know the TYPE of coil you want, a dual output/dual tower with 12v primary and ~3 ohms rating. The DC-1 model is what is used. You'll need to get a separate wire/cap set!
      For the older XS11's, 78-80, folks just bypass the ballast resistor so that the new coils get 12 volts all the time, the TCI will still see 3 ohms on the trigger side so it will be happy.
      • PapaBear1950
        • Sep 2012
        • 36
        • Wichita, KS.
        Yamaha 80
        Suzuki TM 400
        Honda CB 400
        Honda 1800 VTX S
        Yamaha XS 1100
          Hey Bear,
          Sorry, that's DC1-1 dual output, 3 ohm type! The DynaTek website SUCKS!
          See following AMAZON ad:
          http://www.amazon.com/Dynatek-Coil-1...rds=dyna+dc1-1
          Ebay:
          http://www.ebay.com/itm/Dynatek-Igni...-/140740594590
          Example of plug wire kit, note the shape of end for coil.
          http://www.ebay.com/itm/UNIVERSAL-SP...-/170928199069
          Not recommending seller, just has decent description, HOWEVER, these kits do NOT come with all necessary hardware to install...you need to acquire a separate Plug Wire/Cap kit....they use a large round metal compression type clip for the end that fits into the coil body, the wires can NOT just be threaded onto the coils!
            • 9980
            The caps you need Bear are 2- XB05F, and 2- LB05F.
            http://www.motorcycle-superstore.com...T.ac=SLIsearch
            • PapaBear1950
              • Sep 2012
              • 36
              • Wichita, KS.
              Thanks everyone for the help. My head is about to explode with all of this stuff.I feel like a dummy.
              $125 seems like a hell of a lot of money for a coil? I get that you need a dependable one but I'm building this on my Social Security check...LOL
              Greg, I already have the LDO5f but 2 and 3 are XDO5F
              Yamaha 80
              Suzuki TM 400
              Honda CB 400
              Honda 1800 VTX S
              Yamaha XS 1100
                That is for a pair of them.... There's cheaper alternatives, but reliability/quality suffers badly....
                  • 9980
                  I have the ones I listed on my bike.
                    Hey Bear,
                    Others have gotten Coils from a used Honda VF1000, they are dual towered and 3 ohms. See this ebay link:
                    http://www.ebay.com/itm/HONDA-VF1000...-/271064326173
                    I don't know the stats on their output power, but are recommended by the fellows across the pond( UK ) as well as members on this site!
                    The coils look like they use a special screw on wire cap/seal, and I think the wire fits into the coil ON/OVER a screw stub or such down inside the tower, but others can confirm this info....so you may need to look at getting a set of solid core wires that will fit the Honda coils?!
