Spark plug cap resister source?
  • PapaBear1950
    • Sep 2012
    • 36
    • Wichita, KS.
    What is the part # for that coil TC, I put xs1100 in search on the dynatek site and got nothing.
    Yamaha 80
    Suzuki TM 400
    Honda CB 400
    Yamaha XS650 chopper
    Honda 1800 VTX S
    Suzuki C-50 Bobber (wifes)
    HD Road King Classic
    Yamaha XS 1100
      Hey Bear,
      You just have to know the TYPE of coil you want, a dual output/dual tower with 12v primary and ~3 ohms rating. The DC-1 model is what is used. You'll need to get a separate wire/cap set!
      For the older XS11's, 78-80, folks just bypass the ballast resistor so that the new coils get 12 volts all the time, the TCI will still see 3 ohms on the trigger side so it will be happy.
      • PapaBear1950
        • Sep 2012
        • 36
        • Wichita, KS.
        Yamaha 80
        Suzuki TM 400
        Honda CB 400
        Honda 1800 VTX S
        Yamaha XS 1100
          Hey Bear,
          Sorry, that's DC1-1 dual output, 3 ohm type! The DynaTek website SUCKS!
          See following AMAZON ad:
          http://www.amazon.com/Dynatek-Coil-1...rds=dyna+dc1-1
          Ebay:
          Example of plug wire kit, note the shape of end for coil.
          Not recommending seller, just has decent description, HOWEVER, these kits do NOT come with all necessary hardware to install...you need to acquire a separate Plug Wire/Cap kit....they use a large round metal compression type clip for the end that fits into the coil body, the wires can NOT just be threaded onto the coils!
            • 9980
            The caps you need Bear are 2- XB05F, and 2- LB05F.
            http://www.motorcycle-superstore.com...T.ac=SLIsearch
            • PapaBear1950
              • Sep 2012
              • 36
              • Wichita, KS.
              Thanks everyone for the help. My head is about to explode with all of this stuff.I feel like a dummy.
              $125 seems like a hell of a lot of money for a coil? I get that you need a dependable one but I'm building this on my Social Security check...LOL
              Greg, I already have the LDO5f but 2 and 3 are XDO5F
              Yamaha 80
              Suzuki TM 400
              Honda CB 400
              Honda 1800 VTX S
              Yamaha XS 1100
                That is for a pair of them.... There's cheaper alternatives, but reliability/quality suffers badly....
                  • 9980
                  I have the ones I listed on my bike.
                    Hey Bear,
                    Others have gotten Coils from a used Honda VF1000, they are dual towered and 3 ohms. See this ebay link:
                    I don't know the stats on their output power, but are recommended by the fellows across the pond( UK ) as well as members on this site!
                    The coils look like they use a special screw on wire cap/seal, and I think the wire fits into the coil ON/OVER a screw stub or such down inside the tower, but others can confirm this info....so you may need to look at getting a set of solid core wires that will fit the Honda coils?!
