Dozerr,
Congratulations on fixing the carburetor leak! Those can be maddening!
Okay, the engine won't start and:
You know it doesn't have spark because you checked for spark
or
The engine cranks and doesn't start so it might not have spark?
If you haven't already checked for spark, the first thing you need to do is check for spark. Remove one spark plug wire and put a screwdriver in the spark plug boot. Put the screwdriver on the valve cover and take your hand off of the screwdriver, then crank the engine and watch the screwdriver and valve cover to see if there are any sparks sparking anywhere!
or
