connections
Hi Tod,
My reserve lighting unit did not let enough voltage through. Other dirty connections did likewise. Check voltage on each side of the various connections and also the RLU. Also check for bad ground connections (The ground straps at the turn signals are prone to corrosion) Low voltage can sure cause much trouble.,
Good Luck wrenching,
Brent in GA
Hi Tod,
Brent in GA
