At least you answered if it should be hot even with the key off. Thank you. The 30 amp fuse was what was blown and replaced when the wires were touched.
XJ Electrical problem
*Crashed/Totalled, still own -
Tod, I'd still check your stator windings for gounds. That may or may not effect alternator output (so a check of the charging system could show everything as OK) but if one wire/winding is going to ground that could put an AC component into the DC grounding part of the harness. Most of the electrical parts would 'ignore' this, but that 'monitor' may not...
I would have got back faster, but my modem died a few days ago, just got it back on line...Fast, Cheap, Reliable... Pick any two
So how do you do that? Just ohm check the three white wires at the R/R plug to ground?Try your hardest to be the kind of person your dog thinks you are.
Use you ohm meter and see if you have continuity to ground on the rotor from those 2 rings we talked about before.
Have you tried a different regulator?Greg
The list changes.Comment
How is it checking the windings if you're nowhere near the windings? The windings and brushes are just hanging there.. what does checking the rotor do?
And no, I haven't replaced the regulator. It's one of Geezer's. Anyone know how to check it?Try your hardest to be the kind of person your dog thinks you are.
I'm talking about the three white wires from the stator. You should have the alternator cover installed for this check...Fast, Cheap, Reliable... Pick any two
I just went out and have no continuity between the rotor disks and ground. BUT.. When I touched the brushes, one shows @ 5 ohms. The other will flash a high ohm number then go to infinity. It will repeatedly do this every time you touch it. Should they both not be reading the same?Try your hardest to be the kind of person your dog thinks you are.
You need to remove the brushes to check the rotor and stator separately.Greg
??? Still no idea what you're saying, Greg. Remove the brushes out of the cover?
I just went and checked the white stator wires to ground.. no continuity.Try your hardest to be the kind of person your dog thinks you are.
Also went and checked the stator wires to the stator cover. No continuity there either.Try your hardest to be the kind of person your dog thinks you are.
Like I said, I've never seen an XJ alternator apart so I'm just working in my minds eye from my automotive knowledge.
Did you check for grounds in the stator?
Anyone know where the diodes are located on these damn things? In the regulator or the alternator?Greg
Did I not just check for grounds in the stator by testing the white wires to the case?
I just went and replaced the reg/rectifier unit and no change.
Why are we concentrating on the alternator so much if it's charging fine?Try your hardest to be the kind of person your dog thinks you are.
Because it's the most likely cause.Greg
What about my question on the brushes and having different readings?Try your hardest to be the kind of person your dog thinks you are.
Are you testing from the the brushes to ground?Greg
