quick question
  • B.B.
    • Aug 2011
    • 79
    • corsicana , Texas
    quick question
    Ok jus wondering if i can use 79 xs1100 float needle valve and seat and gasket on 80 xs1100 carbs. the reason is i need a jet needle for 1 card and it only comes with the 79 set repair kit. it will save me $15 if i can just use those. any idea?
    Brian
    1980 xs1100 Special - Work in progress
    The jet needles are different and the float needles and seats are different.
    So no, none of the parts are the same.
    • GLoweVA
      • Jun 2011
      • 1957
      • Virginia Beach, VA.
      Looking in my manual, the carb specs for the 80 & 81 specials: Mikuni BS34-111 3J6-00
      Main Jets: 110 & 120 (for the inner 2)
      needle jet: X-2
      Starter Jet: 25
      Pilot Jet: 42.5
      Air Jet main: 140
      Air Jet pilot: 185
      jet needle: 5 GL 16 (part number: 452-14116-16-00)
      Float Height: 23.0 +0.5mm
      for the 80 & 81 Standard: Mikuni BS34-111 3H5-00 (3H5-01 for the 81H)
      Main Jets: 115 & 120 (for the inner 2)
      needle jet: X-2
      Starter Jet: 25
      Pilot Jet: 42.5
      Air Jet main: 140
      Air Jet pilot: 185
      jet needle: 51 Z7 (part number: 360-14116-07-00)
      for the 78 Standard: Mikuni BS34-11 2H7-00
      Main Jets: 137.5
      needle jet: X-2
      Starter Jet: 40
      Pilot Jet: 42.5
      Air Jet main: 140
      Air Jet pilot: 188
      jet needle: 5GZ6
      for the 79 Standard: Mikuni BS34-11 2H7-00
      Main Jets: 137.5
      needle jet: X-2
      Starter Jet: 32.5
      Pilot Jet: 42.5
      Air Jet main: 140
      Air Jet pilot: 180
      jet needle: 5GZ6
      for the 79 Special: Mikuni BS34-11 3H3-00
      Main Jets: 137.5
      needle jet: X-2
      Starter Jet: 32.5
      Pilot Jet: 42.5
      Air Jet main: 140
      Air Jet pilot: 180
      jet needle: 5GZ6
      So you can see the Jet Needles are different from each year. They need to be matched to the Emulsion Tube and Main Jet from that particular year/model.
      Most here will tell you to make sure that any replacement parts have the Mikuki trademark stamped in it.
      80G (Green paint(PO idea))
      The Green Monster
      Got him in '04.
      bald tire & borrowing parts
      Scarlet
      Got her in '11
      Ready for the twisties!
      81H (previously CPMaynard's)
      Hugo
      Cold weather ride
      • B.B.
        • Aug 2011
        • 79
        • corsicana , Texas
        Ok thanks. The jet needle is the long brass needle that springs in tube correct. sorry for the techinical ter
        minology. I have no clue what i am talking about lol
        Brian
          needle jet: X-2
          Starter Jet: 25
          Pilot Jet: 42.5
          Air Jet main: 140
          Air Jet pilot: 185
          needle jet: X-2
          Starter Jet: 25
          Pilot Jet: 42.5
          Air Jet main: 140
          Air Jet pilot: 185
          Main Jets: 137.5
          needle jet: X-2
          Starter Jet: 40
          Pilot Jet: 42.5
          Air Jet main: 140
          Air Jet pilot: 188
          jet needle: 5GZ6
          Main Jets: 137.5
          needle jet: X-2
          Starter Jet: 32.5
          Pilot Jet: 42.5
          Air Jet main: 140
          Air Jet pilot: 180
          jet needle: 5GZ6
          Main Jets: 137.5
          needle jet: X-2
          Starter Jet: 32.5
          Pilot Jet: 42.5
          Air Jet main: 140
          Air Jet pilot: 180
          jet needle: 5GZ6
          Actually, for correction purposes, the 80-81Special stock main jetting IS 110's across all four carbs. These carbs came with the shorter, quicker taper needles and matching main jetting, hence the different jet needle part numbers. BTW, 80-81Standard jet needle(metering rod) is among the unobtanium...NA.
          • CatatonicBug
            • 6117
            • Clinton, UT
            Yep, that's one reason I went with the Dynajet kit. They come with their own set of new needles.
            • mack
              • 2411
              • Ontario, Canada
              I think I might have a spare
              Needle, let me check.
              mack
              79 XS 1100 SF Special
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              https://youtu.be/wB5Jfbp6SUc
              https://youtu.be/RaI3WYHSuWA
              Frankford, Ont, Canada
              613-398-6186
              • mack
                • 2411
                • Ontario, Canada
                Needle
                No sorry, mine are all for early carbs.
                mack
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                613-398-6186
                • B.B.
                  • Aug 2011
                  • 79
                  • corsicana , Texas
                  this is the one i am looking at. will it work? It is silver and mine look brass. sp not sure.
                  Brian
                    • 8798
                    If the number on your needles match the one on the ebay needle, it should work, it will be the same taper.
                    • jwhughes3
                      • 2798
                      • Home of the Alamo
                      Set of four...
                      John
                      '81 XS1100H - "Enterprise"
