Ok jus wondering if i can use 79 xs1100 float needle valve and seat and gasket on 80 xs1100 carbs. the reason is i need a jet needle for 1 card and it only comes with the 79 set repair kit. it will save me $15 if i can just use those. any idea?
quick question
The jet needles are different and the float needles and seats are different.
So no, none of the parts are the same.Nathan
Theodore Roosevelt -
Looking in my manual, the carb specs for the 80 & 81 specials: Mikuni BS34-111 3J6-00
Main Jets: 110 & 120 (for the inner 2)
needle jet: X-2
Starter Jet: 25
Pilot Jet: 42.5
Air Jet main: 140
Air Jet pilot: 185
jet needle: 5 GL 16 (part number: 452-14116-16-00)
Float Height: 23.0 +0.5mm
for the 80 & 81 Standard: Mikuni BS34-111 3H5-00 (3H5-01 for the 81H)
Main Jets: 115 & 120 (for the inner 2)
needle jet: X-2
Starter Jet: 25
Pilot Jet: 42.5
Air Jet main: 140
Air Jet pilot: 185
jet needle: 51 Z7 (part number: 360-14116-07-00)
for the 78 Standard: Mikuni BS34-11 2H7-00
Main Jets: 137.5
needle jet: X-2
Starter Jet: 40
Pilot Jet: 42.5
Air Jet main: 140
Air Jet pilot: 188
jet needle: 5GZ6
for the 79 Standard: Mikuni BS34-11 2H7-00
Main Jets: 137.5
needle jet: X-2
Starter Jet: 32.5
Pilot Jet: 42.5
Air Jet main: 140
Air Jet pilot: 180
jet needle: 5GZ6
for the 79 Special: Mikuni BS34-11 3H3-00
Main Jets: 137.5
needle jet: X-2
Starter Jet: 32.5
Pilot Jet: 42.5
Air Jet main: 140
Air Jet pilot: 180
jet needle: 5GZ6
So you can see the Jet Needles are different from each year. They need to be matched to the Emulsion Tube and Main Jet from that particular year/model.
Most here will tell you to make sure that any replacement parts have the Mikuki trademark stamped in it.Hi, my name is George & I'm a twisty addict!
80G (Green paint(PO idea))
The Green Monster
Got him in '04.
bald tire & borrowing parts
Scarlet
Got her in '11
Ready for the twisties!
81H (previously CPMaynard's)
Hugo
Cold weather rideComment
Actually, for correction purposes, the 80-81Special stock main jetting IS 110's across all four carbs. These carbs came with the shorter, quicker taper needles and matching main jetting, hence the different jet needle part numbers. BTW, 80-81Standard jet needle(metering rod) is among the unobtanium...NA.Looking in my manual, the carb specs for the 80 & 81 specials: Mikuni BS34-111 3J6-00
needle jet: X-2
Starter Jet: 25
Pilot Jet: 42.5
Air Jet main: 140
Air Jet pilot: 185
needle jet: X-2
Starter Jet: 25
Pilot Jet: 42.5
Air Jet main: 140
Air Jet pilot: 185
Main Jets: 137.5
needle jet: X-2
Starter Jet: 40
Pilot Jet: 42.5
Air Jet main: 140
Air Jet pilot: 188
jet needle: 5GZ6
Main Jets: 137.5
needle jet: X-2
Starter Jet: 32.5
Pilot Jet: 42.5
Air Jet main: 140
Air Jet pilot: 180
jet needle: 5GZ6
Main Jets: 137.5
needle jet: X-2
Starter Jet: 32.5
Pilot Jet: 42.5
Air Jet main: 140
Air Jet pilot: 180
jet needle: 5GZ6
Most here will tell you to make sure that any replacement parts have the Mikuki trademark stamped in it.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
-H. FordComment
I think I might have a spare
Needle, let me check.mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Comment
Needle
No sorry, mine are all for early carbs.mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
this is the one i am looking at. will it work? It is silver and mine look brass. sp not sure.
Brian
1980 xs1100 Special - Work in progressComment
'81 XS1100H - "Enterprise"
"Not all treasure is silver and gold"Comment
