think i may be screwed...
  • James England
    • 3039
    • North of England
    #46
    I think they would work......Greg??
      It will bolt right up Nick.
      YICS is something Yamaha did in 82 to the XJ engine. Some engineer decided that the intake ports shold be connected to smoth out the idle and low end acceleration. It worked but it made it a pain to sync the carbs and sorta hurt the top end. Most people have them blocked off.
      • Nick7777
        • May 2012
        • 121
        • Michigan, U.S.A.
        #48
        if you can let me know what shipping to 49646 will be i'll let you know if i can do it this week or not. thanks again guys.
        80 MNS; 81 Venturer
          Some people have swapped heads around with varying results. Common concensus is that if you swap heads from early engines to later engines or vice versa, keep the cams and timing components that belong with the head with the head. that means changing out the centrifugal and vacuum advance components too. different timing curves for different conditions.
          There is som question as to piston to head clearances with putting the early head on the later engins because the later pistons have a hiher dome and the early head has a smaller combustin chamber.
          Scott (3phase) is working on that as we speak. http://www.xs11.com/forum/showthread.php?t=37453
            #50
            You'll want to check piston-to-valve clearances if you swap heads. A early-head-on-a-late-motor combo puts the valves closer to the piston....
              I wouldn't think the valves would be a problem, Steve, as long as the cam timing is correct the valve will be closed when the piston gets there.
              However, the higher piston crown and the smaller combustion chamber could be. That's what Scott will be checking for us.
              • Nick7777
                • May 2012
                • 121
                • Michigan, U.S.A.
                #52
                let me know about shipping on that head greg. post code is 49646.
                80 MNS; 81 Venturer
