stock header problems
  • airborneXS
    • Feb 2012
    • 338
    • Houston, TX.
    well stainless allthread is a no go...snapped three of them in half, the others i bent pretty good...back to the drawing board...
    79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
    09 YZF-R1 " Toothless"
    04 Buell XB12R "Butterfly"
    "I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
    Wolf
    Moto Militia MC
      Don't GM vehicles use the same studs? Greg.......?
        • 9981
        What the heck are you doing, tightening with a breaker bar?
          • 9981
          Actually the Ford 4.6 & 5.4 use the same studs and I have replaced them with the SS rod and eliminated the problem of broken studs.
            • 8962
            I think it was Diver Ray that mentioned the later model metric GM water pump studs will work for our exhaust studs.
            • airborneXS
              • Feb 2012
              • 338
              • Houston, TX.
              found studs at sears...the ss allthread cost me 2.60...at sears each stud was 2.60...WTF!?...found 4 the right size, then had to get 4 that were too long and needed the solid middle part threaded...damn its been a long day...
              the exhaust gaskets were new and needed to be crushed...was using a 1/2 in socket wrench...ugh...oh well, the gaskets are in there, and now all i got to do is finish the last stud, get the new ones in there and the exhaust will be done! i hope...
              Wolf
              Moto Militia MC
                • 9981
                Which engine? Certainly not a V-8. They don't use studs on the 4.8 or 5.3 water pumps or any that I can think of.
                  • 8962
                  Hmmm, from my junkyard days, I would guess a 77 and up (late model ) V8 motor. It might be GM exhaust studs and not water pump studs,
                  Edit: Ok, I did a search and it's late model Chevy small block exhaust studs, they are the longer type that will work on a Standard.
