stock header problems
  • airborneXS
    • Feb 2012
    • 338
    • Houston, TX.
    so i built a custom exhaust using stock headers...i also bought new exhaust gaskets...my problem is that i cant get the header stud nuts started. it almost seems that the exhaust gaskets are too thick, causing the studs to not protrude enough for me to get the nuts on there...ive been messing with it for 2 days now and im EXTREMELY frustrated to say the least...
    79 XS11 special "Loki" - homemade 4-2 exhaust, pod filters, rebuilt forks with progressive springs, tkat fork brace, progressive shocks, rebuilt all brakes and MC's, rebuilt carbs with #142.5 main and #42.5 pilot, a custom front and chin fairing, and a handmade set of saddlebags....
    09 YZF-R1 " Toothless"
    04 Buell XB12R "Butterfly"
    "I had a name at some point, a birth-name, but now everyone just calls me Wolf...."
    Wolf
    Moto Militia MC
    Did you use the headers that came with the bike, or another set? There's two flange lengths, the Special used the shorter ones. If you used '78-79 standard headers, those flanges are longer and the studs will be too short...
    • airborneXS
      • Feb 2012
      • 338
      • Houston, TX.
      the exhaust that came with the bike were 4-1, i got a set of headers from a member on her, and im not sure if they came from a special or standard...so do i need longer studs...im thinking that im just going to remove the studs and use hex head bolts from lowes...
      Wolf
      Moto Militia MC
        Look here... http://www.xs11.com/forum/showthread.php?t=37191 ... for a pic of the two flange types. I don't think the studs will be long enough if you have standard pipes, you'll have to change them...
        I wouldn't use bolts, you'll quickly wear out the soft aluminum threads in the head that way. New studs should be less that $2 each at any decent bolt place.
        • airborneXS
          • Feb 2012
          • 338
          • Houston, TX.
          im not sure where i can find the studs...do u know offhand what the thread type of the studs are? i need to find the studs plus one nut.
          Wolf
          Moto Militia MC
          • airborneXS
            • Feb 2012
            • 338
            • Houston, TX.
            well looking at the pics, im sure that they are standard headers...crap...now i need to find all new exhaust studs and nuts...anyplace online i can order these?
            Wolf
            Moto Militia MC
            • tarzan
              • 1700
              • Chandler,Az.
              Just type "fasteners Houston Texas" in your browsers search box.This brings up lots of places to get them locally. Isn't the internet great?lol
              You should be able to bring in a stud and they can match up the threads and get you the length you need.That would be the most economical option as well as assuring you get the right studs the first time.
              80 SG XS1100
              14 Victory Cross Country
                • 9980
                Are you sure the old gaskets are out of the head?
                Got to a place that sells fasteners, bolts and such, and get yourself a stick of stainless 8mm allthread and make them any length you want.
                • airborneXS
                  • Feb 2012
                  • 338
                  • Houston, TX.
                  8mm all thread, thats a good idea...is it 8mm x 1.25? whats the length for the standard vs the specials? does anybody know that?
                  Wolf
                  Moto Militia MC
                  • airborneXS
                    • Feb 2012
                    • 338
                    • Houston, TX.
                    im sure the old gaskets are out...
                    Wolf
                    Moto Militia MC
                      • 8052
                      Order this and be done with it. You'll have it in a couple days and it will be right.
                      95611-08625-00 BOLT,STUD 3
                        • 9980
                        That is the correct size and thread pitch. As for the lenght.........how much too short are the ones you have? Add enough to make them long enough.
                        • airborneXS
                          • Feb 2012
                          • 338
                          • Houston, TX.
                          You guys are awesome! I never would have come up with the idea to use allthread...i want them to stay in place, 2 questions...
                          1. the studs are only about half as long as the stud wells, should i cut them to be that long, or is it ok to make them long enough to bottom out?
                          2. can i use thread locker to keep them from moving around in there?
                          Wolf
                          Moto Militia MC
                          • trdriver71
                            • 360
                            • Edmonton Alberta
                            I would be careful about using allthread it may be not as strong as a stud.
                            '79 XS11SF
                              • 9980
                              Stainless steel all thread is plenty strong, stronger than OEM studs.
