Rear wheel bearing LEFT side
  • b.walker5
    • Feb 2009
    • 1745
    • Invercargill, New Zealand
    #121
    When i sold my SG, there was a box of parts went with it, including two new rear wheel bearings. I supplied one with the bike, and kept the other. No way was i parting with both of them.
      #122
      I've got three of them and have not needed one yet. Of course if I get rid of them I will need one.
      • James England
        • 3039
        • North of England
        #123
        if you get rid of them, you'll find you need three. That's the way it goes....
        • James England
          • 3039
          • North of England
          #124
          Originally posted by TailspinTommy
          Glad I ran across this thread. I just ordered two of them.
          Thanks for thinking of others, James, and offering these bearings to us while they last.
          Tom
          You're welcome, Tom. The package is now on its way to you, contents described as a low value gift. You should receive it within 10 days.
          • beegshot
            • 85
            • South Carolina
            #125
            Ordered a bearing today
            I already own a Consolidated brand NKIA 5904 bearing that is very similar to the Yamaha part. As soon as I receive my bearing from James, I'll create a post in this thread describing the differences. This may be useful later when the Yamaha specific parts are no longer available. Based on my reading the NKIA 5904 has an inner race that is 0.25 mm narrower than the Yamaha specific part. If that's the case, then a 0.25 mm shim will be needed to install the bearing...or both ends of the spacer could be knurled to make up the gap. I will see and share my results.
            NKIA 5904:
            Inside Diameter: 20mm
            Outside Diameter: 37mm
            Width: 23mm
            Robert
            XJ1100 - Stock
            XV750 - POS parts bike
            • James England
              • 3039
              • North of England
              #126
              NKIA 5904:
              Width: 23mm
              Robert
              No shims are needed and no panic, Robert. People have been buying and installing these bearings for the last 2 years, worldwide.
              • beegshot
                • 85
                • South Carolina
                #127
                Whoops! I did not intend to create confusion...
                Allow me to clarify.
                James is selling the correct Yamaha specific bearing. You can use the Yamaha specific bearing without worry, and without any modifications. Just remove your old bearing and install the new Yamaha specific bearing and put all the inner hub parts back together the way is was. The Consolidated brand NKIA 5904 bearing that I have IS NOT the Yamaha specific bearing that James is selling.
                James,
                I did not intend to create confusion. Please post a response if you are aware of the specific differences between the Yamaha specific bearing (part# 93313-62010-00) and the NKIA 5904.
                Regards,
                Robert
                XJ1100 - Stock
                • duc
                  • Jul 2013
                  • 29
                  • Australia
                  #128
                  anymore left james?
                  1980 XS1100 Standard
                  • James England
                    • 3039
                    • North of England
                    #129
                    Originally posted by duc
                    anymore left james?
                    Three left at the moment....just PM me if you need one...
                    • TailspinTommy
                      • Jun 2011
                      • 11
                      • AK
                      #130
                      James, I received the bearings the other day. Didn't take long to get them. Unique looking things, too.
                      Tom
                      1979 XS1100F "Old General" (work in progress)
                      • James England
                        • 3039
                        • North of England
                        #131
                        Tom
                        Excellent. It's always good to get a confirmation of delivery. The UK to USA postal service is, I must say, excellent. It's very consistent and reliable. You'll be glad you have those bearings one day, Tommy!
                        • beegshot
                          • 85
                          • South Carolina
                          #132
                          Don't order NKIA 5904 Bearings
                          ...the NKIA 5904 bearing is the same dimensions as a (Yamaha Original Equipment) NA 5904 bearing (20 mm ID X 37 mm OD X 23 mm W), but is designed to take a lateral load. Technically, it's called an "Angular Contact Bearing". The reason you don't want to use it in your XS/XJ is because it has both needles and balls. The balls take the lateral load and some of the vertical load. In order to do that in a 23 mm width, the needles are much shorter to make room for the balls. The total available surface area to take the vertical load is smaller than the original equipment NA 5904 bearing.
                          BTW, Motion Industries, Inc. has locations all over the US.
                          Here's a link: https://www.motionindustries.com/mot...sp?q=na%205904
                          Robert
                          XJ1100 - Stock
                            Robert
                            NKIA ? NTN is the bearing manufacturer and NA5904 is the part number. Full width needle roller bearings.
                            Havrn't a clue what your trhowin' in the mix.
                            • CaptonZap
                              • Jun 2010
                              • 1748
                              • Denver
                              #134
                              Robert
                              If a person keeps the bearing CLEAN and lubricated, it would seem reasonable to expect that a 15% reduction in needle bearing length would translate into 15% shorter life of the bearing. (yeah, we can argue about the total load being applied to a smaller bearing area, thus the point load is higher, causing more wear, shorted life span, blah, blah, blah,).
                              But since some of these bearings have made it into the high thousand mile life span, we can assume that Yamaha over engineered the original bearing. Good standard engineering practice. Design for twice the expected load, have half the unexpected problems.
                              So, if the original bearings ever do become unobtainium, it would seem to be a viable option to use the NKIA 5904 bearing, and if you only get 50,000 miles out of it, BFD.
                              The main thing to focus on is to religiously clean and re-lubricate with un-contaminated grease at regular intervals. Someone suggested every tire change.
                              The problem there is that those who do not change their own tires are at the mercy of the greasy thumb mechanic at the local shop, And who knows if he understands that the dirt on his fingers can become part of the new grease that he is introducing into a bearing that was cleaned with solvent that has microscopic dirt particles in suspension, and not blown out with clean air. You can see where this is going.
                              For those of us that do our own work, I see no reason to fear using one of the NKIA 5904 bearings, of James cannot supply an original number bearing.
                              You didn't mention price, and that may be a deciding factor in some people's decision, but that is on them.
                              Thanks for bringing all the info to our attention, it is nice to have alternatives.
                              CZ
                              • James England
                                • 3039
                                • North of England
                                #135
                                Some confusion, it appears? Has anyone ever tried to use one of the angular contact bearings mentioned? I've not heard of anyone trying it but I think I would prefer to stick to full width needle roller whenever possible. Still, if one ever gets desperate........better than nothing, or the two ball bearings side by side.
                                Talking of bearings, I got another six the other week. That makes 9 in my padlocked, unobtanium cupboard. Available to anyone that wants any. Just PM me if you do.
