I have your bearing and one other and a single right hand bearing. I just ordered two sets of new seals from Z1 enterprises and they will be here in a week or two. I'll replace the rear wheel with my spare for the moment and when the seals arrive I'll replace both bearings which will leave me with one left side bearing and one set of seals. The right side bearing are pretty easy to get.
Rear wheel bearing LEFT side
For those interested in prolonging the life of the left side bearing, here is my suggestion.
The spacer sleeve in the left side can be pried out without destroying the seal, if you are carefull. The little spring in the inside collar of the seal may be dislodged, but it can be replaced with no harm done. Once the spacer, seal, and inner race are removed, I use a Dutton Liamson Goldenrod spray can (http://www.bing.com/images/search?q=...4A31F&first=38 full of gas to wash the bearing out. Tilt the wheel with the left side down, and spray the needles while turning them to clean the old grease out. Do not let the dirty fluid to run through the hub to the right side bearing, as all the grunge gets in that bearing.
Once the bearing is clean, repack with grease, replace the inner race and spacer w/ seal, and you're done.
If you are careful when you have the wheel off, you should never get any grit in that side to mix with the grease and cause bearing wear.
You might get a plug of some sort, or put the axle in when you are cleaning the grease out of the wheel splines, to avoid getting that dirty stuff in the bearing.
With clean grease, I don't see why the bearing won't last till the the u-joint gives out. Especially if you clean and grease the bearing every time you grease the splines.
CZComment
Has anyone actually done the rear wheel bearing replacement? Will I need special tools or will a brass drift and butane torch be enough?Automotive Imbecile.
Proud owner of 'The Swiftcicle'. (Swifty for short)
'78E Full Vetter Dresser.
1196 Big Bore Kit.Comment
Yes, I've done several on my bikes. No special tools. You don't need a butane torch either. You need to remove the right side first in order to get at the left hand outer race in the hub. Just drift out the right side bearing. I used a socket set breaker bar and tapped it out. Then, from the right side, you can then get at the outer race of the left side bearing. I seem to remember there are two slots in the casting of the wheel hub. You need a pointed, strong drift of some sort and you tap the outer race first via one slot, then the slot opposite. It takes quite a lot of force but you'll gradually push the race out of the hub.XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
It would be nice to think that, for all the bearings I've sent out worldwide, people will look after them once they are installed in the wheel! Then, like you say, they should last for ages. The bearing seals are important though as, once water/dirt gets in there, they can dgenerate fairly rapidly.XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
Still a few left folks.....XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
Fourteen more bearings
Hi Folks.
I have managed to get 14 more bearings.I still have two left from the last lot, which I put up for sale on eBay after posting here to see if anyone wanted any but I thought it better to take more of them when they were offered to me.
This means I have a total stock of 16 bearings available. If anyone wants any via the forum, please PM me asap. (I need to charge more for them via eBay in order to cover their commissions/listing fees). They work out at $32 each with airmail shipping worldwide at $6.90 on top of that. Two bearings, including airmail shipping, work out at $71. They fit all models of XS1100, XJ1100 and Maxim. Also the XS850. One only of these is required per rear wheel.
Over to you guys and gal.....XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
I've banged away for ages and a piece actually broke off the outside of the bearing but the bearing itself wont budge. These are the slots you were talking about?
I got the right side out easily but look what fell out as soon as I did."
It just disintegrated!
Dan.Automotive Imbecile.
