Hey guys,
New user here as well as "new" 1980 XS1100 Midnight Special owner. I just took my Cylinders into a shop and the guys said I had 2 that were egg shaped and that he could bore them out to 72mm. From what I found, stock bore is 71.5mm. Problem is I can only find the 74mm or 74.5mm pistons. My question is... are there any overheating issues related to these bigger bores that you have noticed. I will most likely go with the cast pistons from Japan as well.
Also, if 71.5mm is stock and the mechanic said he only needs to go to 72mm to resolve the issue, How bad is it really? Should I go ahead and bore them or should the piston rings take care of this issue by themselves.
