Clutch slipping in 3rd
  • petejw
    • 2269
    • sydney australia
    +1 on rons and tc's idea of pulling
    the clutch basket apart and cleaning
    the steels, check for warpage and check
    the fibres while ur at it, the one i recently pulled
    apart had sat for years and the steels were rusted,
    i cleaned them up, added a washer under the clutch
    springs and was good to go.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • jjz28
      • Apr 2012
      • 1023
      • Beckley, W. Va.
      Should i add the washer or buy new springs? The bike just turned over 13000 so maybe just the washer would work and i would not have to wait for parts. That would be nice.
      77 XS750 2D completely stock
        I would just buy the springs, the washer or the extra steel is just a temp fix.
        • petejw
          • 2269
          • sydney australia
          #34
          Ive never needed to replace the springs once ive added
          the washers, all with over a 100 000 k's on the engine the washers used are from a spark plug, u don't
          need to add them under all the springs u just have to add
          them equally and opposite each other, that is do either
          2, 4 or 6, the last time i did this i used 4 washers which
          worked well ive also used washers under all the springs
          this will give u a stiffer feel at the lever tho.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
            • 9980
            +1!!!!!!!
            Put the $18 springs in and it won't be cobbled, it'll be done right.
              #36
              It may work, and I do not doubt you Pete, but it my mind the washers and extra steel thing is a bandaid for weak springs.
              • jjz28
                • Apr 2012
                • 1023
                • Beckley, W. Va.
                #37
                So, this is what i think i will do since i wont lose much if any oil. I will put the washers in and order the springs and when the get here then i will put them in. I dont want any down time. Actually i could ride the bike with no issues now as long as i am not wanting to act like a rocket. But it like being a rocket sometimes. The acceleration in these bikes do impress me and i bet i am actually missing a little power in all gears because of this clutch issue, i just cant tell it cause its not bad.
                  • 9980
                  That's fine but it seems a little silly to take it apart twice. The springs usually don't take more than 2 or 3 days to get to you.
                  But, your bike,your time.
                  • jjz28
                    • Apr 2012
                    • 1023
                    • Beckley, W. Va.
                    #39
                    Well it will probably be a week before i order them and then if the washers and cleaning work, then i wont put them in till later someday.
                    • ViperRon
                      • Feb 2011
                      • 1062
                      • Woodstock, VA
                      #40
                      You may want to get some gasket material to make a new gasket or a new gasket as most times when they have been on a while they tend to tear comming loose. You can lube the new one to help prevent it from sticking. A new one may save some time during the process and you'll have everything.
                      Rodan
                      1980 G Silverbird
                      1198 Overbore kit
                      Grizzly 660 ACCT
                      Barnett Clutch Springs
                      R1 Clutch Fiber Plates
                      122.5 Main Jets
                      ACCT Mod
                      Mac 4-2 Flare Tips
                      Antivibe Bar ends
                      Rear trunk add-on
                        • 9980
                        Gasket? Who needs a gasket? Get some Yamabond or some ThreeBond 1194 (what I use) and clean off the old gasket and just use that.
                        • jjz28
                          • Apr 2012
                          • 1023
                          • Beckley, W. Va.
                          #42
                          I got back from a ride a little bit ago, while i was riding i was at a stoplight and was seeing how far i had to let my clutch out before it started pulling and it didnt start pulling until almost all the way out. Could it just be out of adjustment? I know it is out for sure but would that make it slip? I probably wont adjust it until the weekend cause i go back to work tomorrow.
                            #43
                            Yep, that's out of adjustment....
                              #44
                              Hey Jeff,
                              The Engine side clutch adjustment does NOT require taking the crankcase cover off, just the small inner cover that's held on by 2 phillips screws. Then you use a Phillips driver along with IIRC a 12mm box end wrench. First, use a pair of pliers to loosen the handle lever and provide a little slack in the cable, then perform the engine adjustment. Unlock the center lock nut, then use the screwdriver, turn it OUT a full turn or so...then while holding the lock nut with the box wrench so it won't yet turn, screw the philips back in until it just makes contact with the inner throwout pin....you'll feel the extra resistance then back it off a 1/4 turn, and then LOCK it in place with the box wrench. Then test readjust the slack at the handlebar, and then test the feel and see how it behaves or if it still slips! Shouldn't take you more than 10 minutes to do this with just a few tools.
                              • jjz28
                                • Apr 2012
                                • 1023
                                • Beckley, W. Va.
                                #45
                                Thanks TC, If i get off work on time today, i am going to do this. I was planning on riding to work today but not sure yet. If i have time before i leave, that would be a good time to do it so I could "test" it on the way to work.
