anyone tried putting the mikunis off a gs1100e onto the xs11. the ones that i have been looking at are 34mm and from the early 80's so i'm curious if they could be modified to work. any input would be appreciated.
Carb swap
The spacing is different as you can see here..... GS on the left, XS on the right.
And being the carb throat is smaller too you will play hell getting them installed and sealed.Last edited by BA80; 05-16-2012, 04:59 PM.Greg
The list changes. -
People have use the Kawasaki ZRX carbs and have reported good results. If you were considering purchasing a different set I would go with the ZRX's.'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
"What they do have is an implacable, unrelenting presence and movement that bespeaks massive power lurking behind paint and chrome. They don't wail like a screeching ninja, the don't rumble like a harley. They just growl like a spactic, stressed out badger waiting to rip your face off and eat your soul." Trainzz~RIP~Comment
Your welcome Nick. I just happend to have that set of GS carbs here that came with the last XS parts bike I picked up, uninstalled of course, so I could show you the comparison.
Glad I could help and save you some grief.
I had the same thoughts when I got this thing home but after some study I found that it would be virtually impossible to make it work right.Greg
The list changes.Comment
GS1100 carbs
Yep..they will work. If my memory serves me right the only difference is the spacing on the rack.78 XS1100E Standard
Coca Cola Red
Hooker Headers
http://i408.photobucket.com/albums/p...m/DSC00580.jpg
1979 XS1100 Special
http://i408.photobucket.com/albums/p...m/DSC00612.jpg
1980 XS Standard
http://i408.photobucket.com/albums/p...m/DSC01137.jpg
2006 Roadstar Warrior
http://i408.photobucket.com/albums/p...um/warrior.jpgComment
Maybe just switch the racks?
Foreda beat me to it. But if Greg says the throats are different diameter, you got a problem.
NICK: Do you have any carbs now to draw parts from? i might have another solution for you. PM or email me.Tom Clisham
79SF 1 owner,8000 miles, restoring to completely original ( I hope) GONE TO FRANCEComment
As one of those who switched to the Keihin carbs from a ZRX, I respectfully ask the question; why make the switch from early 80's Mikunis to another set of early 80's Mikunis from another make of bike?
The reason I switched to the Keihins (aside from the performance aspect) was that the ZRX rack is 20 year newer technology, parts are easier to find, they take and hold a tune-up much more easily and are vitrually a plug-n-play deal.
Here is a pic or two of my 36mm carbs. They are from a 2001 ZRX-1200. Whole deal was under $200.00 (including the new filters and choke set-up) and the performance is like night and day compared to the 70/80's era Mikunis. So if you are changing to different carbs then, this (or something similar) is the way to go. Plus, they have a neat idle speed adjustment knob at the bottom of the #1 carb.
Mike Giroir
79 XS-1100 Special
Once you un-can a can of worms, the only way to re-can them is with a bigger can.Comment
Hey Nick. Granted I got a steal of a deal on the carbs but they do pop up on Ebay from time to time and I am sure there are others that will do the trick too. I have seen sets off of slightly older 1999 ZRX-1100's more often there. They are the same carburetor but you will need to re-jet them to much larger jets. But then, you would need to re-jet anyways.Mike Giroir
79 XS-1100 Special
First search I did for zrx carbs on ebay came back with 6 racks for right about $200.Nathan
Theodore RooseveltComment
If you guys are still out there, the KTRIC is simply a throttle position sensor used as part of the equation to adjust timing advance. Will have no bearing for use on the XS.
Most guys (myself included) disconnect the KTRIC on the ZRX as it changes the timing (more advance) below 4k rpm to give a more favorable throttle response.Howard
ZRX1200
BTW, ZRX carbs have the same spacing as the XS11... http://www.xs11.com/forum/showthread.php?t=35462Comment
