Carb swap
  • Nick7777
    • May 2012
    • 121
    • Michigan, U.S.A.
    Carb swap
    anyone tried putting the mikunis off a gs1100e onto the xs11. the ones that i have been looking at are 34mm and from the early 80's so i'm curious if they could be modified to work. any input would be appreciated.
    80 MNS; 81 Venturer
    The spacing is different as you can see here..... GS on the left, XS on the right.
    And being the carb throat is smaller too you will play hell getting them installed and sealed.
    • WMarshy
      • Apr 2009
      • 2402
      • Mexico NY
      People have use the Kawasaki ZRX carbs and have reported good results. If you were considering purchasing a different set I would go with the ZRX's.
      '79 XS11 F
      Stock except K&N
      '79 XS11 SF
      Stock, no title.
      '84 Chevy K-10 "Big Blue"
      • Nick7777
        • May 2012
        • 121
        • Michigan, U.S.A.
        thanks greg, you saved me some money, and now my carb hunt continues...
        80 MNS; 81 Venturer
          Your welcome Nick. I just happend to have that set of GS carbs here that came with the last XS parts bike I picked up, uninstalled of course, so I could show you the comparison.
          Glad I could help and save you some grief.
          I had the same thoughts when I got this thing home but after some study I found that it would be virtually impossible to make it work right.
          • Nick7777
            • May 2012
            • 121
            • Michigan, U.S.A.
            yeah im new to the motorcycle world, but i work in a machine shop so fabricating things is a bit easier... but im gonna take your word for it on these haha
            80 MNS; 81 Venturer
            • foreda
              • 949
              • Southwest Louisiana
              GS1100 carbs
              Yep..they will work. If my memory serves me right the only difference is the spacing on the rack.
              78 XS1100E Standard
              Coca Cola Red
              Hooker Headers
              1979 XS1100 Special
              1980 XS Standard
              2006 Roadstar Warrior
              • tom clisham
                • Sep 2010
                • 627
                • Northern Illinois
                Maybe just switch the racks?
                Foreda beat me to it. But if Greg says the throats are different diameter, you got a problem.
                NICK: Do you have any carbs now to draw parts from? i might have another solution for you. PM or email me.
                Tom Clisham
                Age is relative YOU WON"T GET OLD TIL YOU SELL THE BIKE
                _____________________________________________
                '78xs1100E ,all stock & original GONE TO WISCONSIN
                '80 SG Vetter fairing,hard bags,trunk,fork brace,
                stock headers with fishtail mufflers,black & beautiful GONE TO ARIZONA
                79SF lowered,jardine 4/2 exhaust,pod filters,drilled rotors,fork brace, bar hopper
                79SF 1 owner,8000 miles, restoring to completely original ( I hope) GONE TO FRANCE
                  Not only is the GS rack about 1" narrower, the end that fits into the intake boot is 40mm where as the 1100 carbs are 42mm.
                  • TADracer
                    • 1417
                    • Kenner, Louisiana USA
                    As one of those who switched to the Keihin carbs from a ZRX, I respectfully ask the question; why make the switch from early 80's Mikunis to another set of early 80's Mikunis from another make of bike?
                    The reason I switched to the Keihins (aside from the performance aspect) was that the ZRX rack is 20 year newer technology, parts are easier to find, they take and hold a tune-up much more easily and are vitrually a plug-n-play deal.
                    Here is a pic or two of my 36mm carbs. They are from a 2001 ZRX-1200. Whole deal was under $200.00 (including the new filters and choke set-up) and the performance is like night and day compared to the 70/80's era Mikunis. So if you are changing to different carbs then, this (or something similar) is the way to go. Plus, they have a neat idle speed adjustment knob at the bottom of the #1 carb.
                    Mike Giroir
                    79 XS-1100 Special
                    • Nick7777
                      • May 2012
                      • 121
                      • Michigan, U.S.A.
                      those are sweet, unfortunately i can't find a set of those for anywheres near that price... i would preferf that set up because it makes perfect sense(in theory).
                      80 MNS; 81 Venturer
                      • TADracer
                        • 1417
                        Hey Nick. Granted I got a steal of a deal on the carbs but they do pop up on Ebay from time to time and I am sure there are others that will do the trick too. I have seen sets off of slightly older 1999 ZRX-1100's more often there. They are the same carburetor but you will need to re-jet them to much larger jets. But then, you would need to re-jet anyways.
                        Mike Giroir
                        79 XS-1100 Special
                          First search I did for zrx carbs on ebay came back with 6 racks for right about $200.
                          • Nick7777
                            • May 2012
                            • 121
                            • Michigan, U.S.A.
                            the ones i have been looking at have a "K-tric" sensor... any issues with them
                            80 MNS; 81 Venturer
                              • 3372
                              If you guys are still out there, the KTRIC is simply a throttle position sensor used as part of the equation to adjust timing advance. Will have no bearing for use on the XS.
                              Most guys (myself included) disconnect the KTRIC on the ZRX as it changes the timing (more advance) below 4k rpm to give a more favorable throttle response.
                              2001 ZRX 1200
                              1982 Seca 750
                              1983 Nighthawk 550
