emergency kickstart?
  • Cuda 69
    • Jan 2012
    • 676
    • Greenwich N.Y.
    my 80 special has a cover over emergency kickstart,is this functional?and if so where was the kickstart stored?
    FOXS-XS11SG
    1980 XS11SG-sold
    1999 Vulcan classic-sold
    1982 XJ 650-sold
    • 9980
    Is the cover you speak of a round black plug in the sidecover or a rubber boot over a splined shaft?
    • jjz28
      • Apr 2012
      • 1023
      • Beckley, W. Va.
      I just found mine today on my special. If it is the spline covered with the rubber cap then the kickstarter is behind a nut right behind it on the frame. I was taking that nut loose to see what it was and there was my kickstarter. The nut goes through the hole on the kicker and the rest of the kicker is hidden up in there. Its really pretty neat.
      77 XS750 2D completely stock
        Hi John,
        If your bike has slotted rotors it's a true '80 and that's the year they cheaped out on the kickstart pedal, the stowage for it and the shaft & gears in the tranny that made it work.
        They were even too cheap to modify the molds to remove the lettering that said kickstart
          • 3193
          Yup an 80 should just have the rubber set into the case with no kickstart shaft sticking out to put the emergency starter on. Like Fred says they cheaped out that year.
            • 9980
            I was just thinking that if it's like the two SGs I have, one has a 78 engine and the other has a 79 engine and the both have the kickstart shaft with the rubber cover.
            A lot can happen in 32 years.
              • 3193
              Absolutely correct there Greg. My 81MNS has a 79SF motor in it.
              • Troney
                • Mar 2012
                • 48
                • Winnipeg, Manitoba, Canada
                I'll have to check when I get home I seen the plug on my 82 xj but dunno if anything is behind it.
                82 XJ1100
                  • 3193
                  The later model (80/81) kickstart looks like..
                  The early (78/79) looks like..
                  • Cuda 69
                    • Jan 2012
                    • 676
                    • Greenwich N.Y.
                    well that sucks,yammie screwed me out of a kickstart. yep,I got a true 80.
                    FOXS-XS11SG
                    1980 XS11SG-sold
                    1982 XJ 650-sold
                      • 9980
                      If it has just a plug the kickstart mechanism isn't there. I don't think the XJ even has any of the gears in there. Like the LATE XSs.
                      • Cuda 69
                        • Jan 2012
                        • 676
                        • Greenwich N.Y.
                        I just told my wife,if the battery dies,she's gotta be the kickstarter and push me and the bike down the street till it starts.Won't tell you what she said,don't want to offend any virgin ears.
                        FOXS-XS11SG
                        1980 XS11SG-sold
                        1982 XJ 650-sold
                        • Cuda 69
                          • Jan 2012
                          • 676
                          • Greenwich N.Y.
                          just got a plug Greg, I saw the words kickstarter,and got excited.false alarm
                          FOXS-XS11SG
                          1980 XS11SG-sold
                          1982 XJ 650-sold
                            • 9980
                            The SG has part of what is needed. The kickstart parts from an older engine will slip right in there without too much trouble. The plug needs to be removed and a seal installed and all the other parts can be installed by just removing the clutch cover. The inner part of the rachet gear is already there.
                              Too bad even push starting won't even get it started if the battery is below 10.5 volts!
