emergency kickstart?
The list changes. -
Another thing lacking is the locating dowels used for the cover; OEM is just thin sleeves, I'd want to see a solid dowel, at least at the back where the stress is.Fast, Cheap, Reliable... Pick any two
Good point. I never thought of that. I did start my bike with the kickstart to see how easy it was to start (dead easy actually) but I was acutely aware that it's a lot of weight on that shaft and casing when you boot it. The hole is braced in the casting on the inside but it's pretty weedy.....XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
I just got my permanent kickstart lever in the mail from Tom Clisham. Thanks Tom. Now to install it.
There is the pic of the right side. Towards the front there is the rubber plug sticking out. How do I take that off? I did not try yet as I did not want to break anything. Does it just pop off and I mount the lever? Once I do this I can see if the compression is any good and I can move forward with my build. Thanks in advance guys.
BTW: It is a 79 specialRich (Ringo)
'79 XS11 Special
'02 VTX1800C (I know not a Yama but still mine)Comment
Just pop it off with a flat tip screwdriver. Never tride to use the kickstart to check compression so I don't know if it will give correct readings.Ty
78 XS1100E - Now in Minnesota
80 XS1100LG - The Punisher
82 XJ1100 - Daughter's Bike
72 Yamaha Mini JT2 - Youngest Daughter's bike (She wants a bigger one now)Comment
I was told doing that will raise the compression in the chamber. It may not be a fully consistent reading but it will show if the engine is holding compression, I was told. Am I wrong? The bike has no battery and not sure about the electrical system. I wanted to test this first to see where my next step was, whether it was doing the engine over or the rest of the bike. Opinions?Rich (Ringo)
'79 XS11 Special
I doubt if you'll get a accurate reading with the kicker; you'll get something, but probably not what it really has.
If you want to test the compression, use a car battery and some jumper cables. Lift the starter cable off the solenoid, then just apply 12 volts to that directly to spin the motor. Pull all the plugs and the carbs to get the best results....Fast, Cheap, Reliable... Pick any two
thanks crazy steve, will the battery from my other bike do the same trick? i dont actually need to start the motor just get it spinning. would an air ratchet on the crank work too?Rich (Ringo)
'79 XS11 Special
Sure, another bike battery will work. It may not have enough poop to spin the motor the (at least) four times it will take though...
The air ratchet won't spin it fast enough.Fast, Cheap, Reliable... Pick any two
