I just did a quick search and came up with this:
12R-12121-00-00
http://www.partspak.com/ProductCart/...product=131182
For $35.36. Not too bad.
Other sites had them around $60
I had a slightly bent valve on my SG. The exhaust valves on the 80-81s are a lot harder to find.
12R-12121-00-00
i could get a whole new head for a bit more from the scrapyard.
Well, you should at least check the other valves while the head is off. Check them to see how fast solvent leaks through the seated vlaves. As far as the new valve, I would lap that one. Lapping is done with compound, while turning the valve in the seat. Sure the valve is ground (or should be) but it needs to mate to the seat. I rarely disagree with Motoman, but I do in this case.
