Cracked exhaust
    Originally posted by Vinnie48
    here's a bigger pic ..sorry I use Flicker not Photobucket and still learning how to post the real image here , not the link.
    http://farm8.staticflickr.com/7276/7...39177f8c_z.jpg
    Bummer.... can't weld that up and hide it . You might look and see if you can find another left-side muffler assembly before you hack both pipes up....
    • Vinnie48
      • Mar 2012
      • 34
      • Nortwestern Illinois
      I've been searching for it on e-bay but really difficult to find a good one.
      I'm thinking about buying a HD or Vance & Hines slip ons instead.
      • Vinnie48
        • Mar 2012
        • 34
        Originally posted by Brad
        Mine seem fine, sound great and very little modification, Vance & Hines straight shot slip on's. Bought them for $150 or $200 used.
        Disregard my prev question ...I didn't pay attention to your description of the exhaust " Vance & Hines straight shot slip on's " ...
        • Vinnie48
          • Mar 2012
          • 34
          My new set of exhaust from niche cycle parts has arrived and will replace the exhaust tmrw...no choice but to cut it off because there are holes on both left and right side.
          • daveyg
            • Feb 2009
            • 411
            • Boise, ID
            The links u posted works, but if u want the actual image to show up on here u need to insert that link in between [IMG] and [/IMG] or you can click on the icon above the new post text box that looks like mountains on a yellow background, and insert that link in the popup generated by that icon. I saw the pic, and must say, that is a very odd spot for it to crack, usually they crack where the factory welds are or along the bottom, not across the top. Good luck getting it welded right there, if it were mine I would shoot for some H-D muffs.
            BARE BONES CHOPPERS: If it don't make it go faster, you don't need it!
            80 XS1100SG(cafe in progress *slowly)
            • Vinnie48
              • Mar 2012
              • 34
              Thank you . I will try to post some pics when finished.
                • 5069
                Originally posted by GLoweVA
                Hasn't some put Harley mufflers on?
                I put some on. They don't have as deep a tone as stock or Jardine 4-1. I couldn't get the sluggish midrange transition sorted-out without adversly affecting other throttle positions, so I took them back off.
                • Vinnie48
                  • Mar 2012
                  • 34
                  my new exhaust
                  installed this the other day ...not the best looking exhausts but the sound is okay!
                  I won't waste my time fixing this, the right exhaust also has a hole 3/4 dia.(approx)
                  goodbye old man!
                    I would (hesitantly) suggest carefully cutting them open to see how the things are baffled and how the exhaust is forced to flow through the muffs.
                      • 6762
                      Nice Job Vinnie, new muff dont look bad at all...Looks like it was time to toss those muff anyhow...
                        OK.. Spill. Where'd ya get the exhaust and how much? I like those much better than the Harley or Mac turn-out mufflers.
                          +1..........those look like they 'belong' there!
                          • Vinnie48
                            • Mar 2012
                            • 34
                            thx
                            @ Natemoen, I'm gonna thow it away anyway so I'll try to cut it open one of these days and post some pics , it would be intereting to see how it's baffled inside.
                            @madmax-im ,Thanks... I agree , it would be a lot of work if I attempt to fix it.
                            @trbig , I bought the mufflers from Niche Cycle Supply ...here's the link below:
                            @motoman, thanks.
                            thanks for your comments , makes me want to post more pics
                              Vinnie, thanks for the link to that exhaust.
                              Not to say you should not cut that exhaust up, but HERE is a link to where I did the same thing to one I had that was rotted out.
                              • Vinnie48
                                • Mar 2012
                                • 34
                                Hi DGXSER,
                                Your're welcome... and thanks a lot for that link to that thread ! I therefore don't have to do it on mine...saves me time !
                                @ Natemoen , pls. see the link provided by DGXSER. thanks
