TKAT Forkbrace on an XJ???
Ben, you'll notice the difference right away!........even leaving a stop sign and turning a corner. Reaction of the front increased incredibly. Just a test as is.....put the scoot on the centerstand, grab the left bar standing beside it and sharply jerk it back and forth while watching the front of fender and front of tire. That seperate movement of both is TOTAlly eliminated with the TKat brace! On top of that, the slider guides in top of fork tubes recieve less wear(another unobtanium) and tire wear is more even and reduces the cupping, some of which can't be helped with the front braking even though yours is linked. Stability is beyond comparison in windy conditions, specially with a fairing mounted or large widshield. With the leading front forks like the Specials, likely be the same fork brace.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Thanks Brant and everyone else for your input...looks like $95 will be well spent...gonna pull the trigger on this item tmrw. Looks to be as easy an installation as one could ask for... Oh and Brant I'd have to remove the exhaust to re-install the centerstand...
2005 Honda SilverWing 600
2018 Honda PC-Xpress 150Comment
My TKAT brace has only a couple of millimeters clearance on the fender. I expect it won't fit the XJ without swapping to a XS fender. I'm pretty sure that's going to be the case.Marty (in Mississippi)
XS650EComment
I talked to that Tkat guy in emails a while back, and he told me at that time that the XJ was a bit different height than the XS. Someone might take some measuerments.
OR.... I can't do it today since I'm not home, but I've got the Tkat brace on my '81 special. I can try to put it on the XJ and see if it's going to fit.Try your hardest to be the kind of person your dog thinks you are.
sure I can wait...no rush to spend 95 bucks to find out its a no go..I talked to that Tkat guy in emails a while back, and he told me at that time that the XJ was a bit different height than the XS. Someone might take some measuerments.
OR.... I can't do it today since I'm not home, but I've got the Tkat brace on my '81 special. I can try to put it on the XJ and see if it's going to fit.2005 Honda SilverWing 600
Oh that? I never got it...have a badassed kerker on there now...and love it...worth not having the CS on there. My feeling is that what Steve and Marty said about the possibility of needing an xs fender to get it fit right...might be how to go here...hope notLast edited by madmax-im; 03-08-2012, 07:11 AM.2005 Honda SilverWing 600
Maximan had a TKAT brace on Godzilla. Seems like I remember him having to run a Special front fender. Worked great, and he pushed the performance envelope.1980 XS 11 Special: The King of Kong, 9th wonder of the world. Pacifico fairing, chopped shield, Yamaha hard bags, Diamond seat, T-Kat fork brace, XJ top end, YICS Eliminator, '80 carbs from Spyder Cycle Works, K&N Air filter, Fuse block, stainless steel valves & reg/rect from Oregon MC Parts. Raptor CCT, XJ air shocks, 850 FD, Sportster mufflers, Standard handle bar, Tusk Bar Risers, SS braided brake lines. Cat Eye speedometer. HID projector beam headlight, LED running lights.Comment
A Special fender from any year or any model except XS650 or XS400.
I say forget the brace for now and go to emulators and straight rate springs.
XS650EComment
1970? Honda Z50... gone
1974? Yamaha 100 Enduro... gone
1974 Honda CB200... gone
1981 Yamaha Virago 750... gone
1993 Honda Shadow 1100... gone
2008 Honda VTX 1800F
1982 Yamaha XJ1100J w/850 final, Raptor ACCT
1979 Yamaha XS1100SF "Chewey" Raptor ACCT
http://www.johnsoldiron.comComment
I did it to mine, and it's like a new bike! I've been tweaking it after speaking to Matt Wiley of Race-Tech. Here's what they are: http://www.racetech.com/page/title/Emulators
I spent a good bit of money making errors. I would recommend you call Traxxion Dynamics. 770-592-3823 They did my springs. To do it over I would have them set up the whole thing. They deal in Race-Tech's emulators and sell them cheaper than Race-Tech does. You can have a new front suspension for the price of an inexpensive pair of shocks. (Their website won't tell you this) The only thing it won't fix is the spindly forks. TKAT helps that a good bit, but doesn't cure the shortcomings entirely.
As soon as I drove 100 yards, I could feel the difference, especially braking.
XS650EComment
I don't know if they have the same guard as an XJ, but the XS1100RH's have the same forks. Here's a snap of the TKat Special brace fitted to Steptoes RH. Fitted straight on and he keeps raving about the handling benefits.
*"The Keg"- UC torana hubs, XS11 discs, Tokico 4 spot calipersComment
