center drive hand gernade?
  • XJfan1
    • Feb 2012
    • 180
    • Huntington,Indiana
    I got my bike off craigslist about ten days ago. Finally got to change all the fluids today. The center drive plug came out covered in shavings no oil came out and it was full of oil. I poked a screw driver int the hole and knocked a load of shavings loose and then the oil came out. The shavings were actually were. Plugging and drain hole. So I re filled it with gear oil and ran it one the center stand through a couple gears and to my suprise no noise or grinding just smooth. I took it out and ride Around my 4 acre yard a few times. Seemed good so I hit the road went about 3 miles till I got cold "I'm in indiana" it seems good. What do you guys think. With that many shavings you'd think it would act funny our at whine. By the way that was my first ride on a yamaha street. I have owned a few other brands but nothing with this kind if power. Smooth as silk and she arches her back when you romp on her. I'm in love.
    1982 xj 1100
    "The Ape"
    http://youtu.be/AiQ8CqclHr4
    Shavings??? That's not good.... For peace of mind as well as safety, I'd personally replace it. You don't want that seizing on you at any speed above a fast walk. Middle drives aren't that hard to find, and far cheaper than the possible 'other' damage you'd see if it locks up.
      • 7941
      I second that! I wouldn't ride it anywhere.
      • XJfan1
        • Feb 2012
        • 180
        Is that a pain to change?
        1982 xj 1100
        "The Ape"
        • petejw
          • 2269
          • sydney australia
          not at all,
          u want to drain the oil out of it first,
          undo the 4 bolts that attaches to the uni joint/driveshaft
          undo the allen key bolts around the middle drive and pop
          it out, theres 2 allan keys that hold the front cover on the m/d
          that dont need to be loosened.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          1981 xs1100 RH (aus) (5N5)
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
          • XJfan1
            • Feb 2012
            • 180
            If anyone has one they want to sell I'm in the market for one.
            1982 xj 1100
            "The Ape"
            • CaptonZap
              • Jun 2010
              • 1748
              • Denver
              By the by, there is another drain plug that drains the part of the main case that houses the input side of the middle drive. When you get it out, you will see the oil in there.
              You have to crawl under the bike and look up to find the plug. It is in a recessed hollow in the case.
              You want to get it cleaned out before you reinstall a new drive, so that you don't contaminate the fresh oil. CZ
                • 7941
                search XS1100 middle drive on eBay and there are a bunch of them. I saw one in Indiana.
                You may wish to contact member andreashweiss. He takes care of us here.
                • XJfan1
                  • Feb 2012
                  • 180
                  Awesome thanks for the info. You guys are the greatest thing since sliced cheese.
                  1982 xj 1100
                  "The Ape"
                    Quick ebay search, these are the cheaper of the ones on there.
                    http://www.ebay.com/itm/1979-yamaha-...ht_1126wt_1270
                      Originally posted by petejw
                      not at all,
                      Pete, the left allen screw on that cover is the long one that has to come out also.
                      • petejw
                        • 2269
                        • sydney australia
                        hey todd, ur right, i was thinking there was only 3 bolts
                        holding the cover on not 4.
                        pete
                        new owner of
                        08 gen2 hayabusa
                        former owner
                        zrx carbs
                        18mm float height
                        145 main jets
                        38 pilots
                          • 5062
                          I think the idea is that the cover can stay on if you remove the correct bolt. I have seen these middle drives on ebay from time-to-time where they have been disassembled. I wouldn't consider one of those because of the way they are put together with shims... Also, once I bought an "xs11" middle drive from ebay that was from a different model. That one looked identical except the cover (cap) had three bolts instead of 4.
                            • 5062
                            I should have said, make sure it is for an xs11. The one from he other model (what ever that was) bolted up, but leaked because (I think) it was missing that other bolt location.
