Fuse Box
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Fuse Box
    OK, I got my little fuse box today and it has a back weather cover on it. I noteced in some of the pic's it was left off Is this for clearance or what? Also, if I understand correct, on my 79SF, I dont need to bother with the fuse that is outside the OEM box, below and to the left?
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    Mine didn't have any 'back cover' (or if it did, I threw it away first thing), but it's not anything that's needed. As to the 'accessory' fuse, you can leave it, remove it altogether (unless you're planning on hooking something to the bike like a GPS), or move it into the new panel but you'll have to rig a terminal... easiest to just leave it.
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      Pic
      Here is what came with it
      Guessing that back is a weather cover?
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
      • CatatonicBug
        • 6117
        • Clinton, UT
        Mine didn't have a weather cover either. Would have been nice though. I packed mine with dielectric grease and put a piece of cardboard over the back. Since you've got one, I'd say to use it! Remember to grease the fuse connections though. And yes, you can ignore that aux fuse altogether.
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          Thanks
          Thanks guys, the back cover doesnt add much thickness, so I will use it. TopCat must be sell his on the black market
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
          • mack
            • 2411
            • Ontario, Canada
            adapter
            I believe thats a mounting adapter. Your holes on the block will not line uo exactly with the mounting panel. Mine didn't come with that so I think it's an upgrade for an identified problem.
            mack
            79 XS 1100 SF Special
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            https://youtu.be/wB5Jfbp6SUc
            https://youtu.be/RaI3WYHSuWA
            Frankford, Ont, Canada
            613-398-6186
            • XS1100_OEM4ME
              • Mar 2009
              • 1619
              Holes
              I have seen on here where many have ground down the ears on these to make the sit level, I dont want to grind on the case and weather back and damage the seal, so Can I just drill two holes at the top and install it as an angle?
              1980 XS1100 Special
              1990 V Max
              1982 KZ750 LTD Twin
              1974 CB750-Four
              Past/pres Car's
                • 7863
                I elongated the holes with a little round file and used the mounting points from the OEM fuse box. My installation looks OEM.
                • mack
                  • 2411
                  • Ontario, Canada
                  Mounting bracket
                  For the SF , I made this one from a scrap piece of sheet metal I had. I didn't need to but I wanted to add some rubber washers to act as vibration dampers.
                  Finsihed
                  mack
                  HERMES
                  original owner
                  81 XS 1100 LH MNS
                  SPICA
                  78 XS 11E
                  IOTA
                  613-398-6186
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    AMPs
                    OK, NOW, I am reading the specs on the little fuse box, Max Amp per fuse is 15 amp, Max amp per fuse box is 45 amps With the OEM fuses being 30 amp, 20 amp, 10 amp, 10 amp, for a total of 70 amps Any problem with this, should I use two plugs with two 15 amp fuses for the for the 30 amp circurt?
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                      That backplate isn't a seal, it's an additional retainer for the fuse contacts which just snap into the plastic housing. These boxes aren't sealed unless you apply sealer to all seams. Even at that, you still have the exposed tabs where the wires hook up for a corrosion point...
                      As far as running parallel fuses, don't do it. Even the slightest difference in resistance between the two sockets will bias the current to the lower resistance and you'll likely have issues. That appears to be the same panel as TC sells (and I've seen them elsewhere too) and all those can use a 30 amp fuse. Also keep in mind that a particular fuse size doesn't mean that's how much current you need. Fuses shouldn't be run any higher than 80% of their rating or you'll have nuisance failures. Realistic values for circuit current are probably about 6-7 amps for the ignition system and about the same for lighting, everything else is intermittent loads so your 'normal' load on the box is under 15 amps...
                      • XS1100_OEM4ME
                        • Mar 2009
                        • 1619
                        Seal
                        So a bead of RTV around the back and at the term's at the box, my cover has a gasket built in, so then all would be water resistant
                        1980 XS1100 Special
                        1990 V Max
                        1982 KZ750 LTD Twin
                        1974 CB750-Four
                        Past/pres Car's
                          • 8767
                          That area behind the sidecover won't get wet (well maybe just a little) unless you ride the bike into a canal.
                            That area behind the sidecover won't get wet unless you ride the bike into a canal.
                            ... at which point a waterproof fuse box won't be much help....
                              • 8767
                              I don't have that type of fuse box, I have a gang type box and I chose to solder all the connections instead of using spade terminals.
