Valve Adjustment Pictorial
2-79 XS1100 SF
2-78 XS1100 E Best bike Ever
Couple of more parts bikes of which 2 more will live!Comment
I like the pictorial but do have a question?
I rotated the 19mm timing plate bolt until the T was at the arrow and the dimples on the crank are on top at the notch and the sprocket bolts are high on the backside.
Now your instructions say to rotate the crank so that the dimples are not showing.
Do I rotate the 19mm timing plate one rotation (360 degrees) or do I only watch the crank and only turn the 19mm timing plate enough to rotate the crank 180 degrees?79 XS11Comment
One complete rotation of the crankshaft (19MM plate) equals 1/2 turn of the camshafts, so that would bring the two dots down to the bottom.2H7 (79) owned since '89
☮Comment
Aren't you considerate? and thank you... no worries here though. Between being in the Army and having a job as a bartender for a number of years... I'm not easily offended.
and yes, we have a few "XSettes" here now. From what I've seen of their posts though, I don't think they are easily offended either.
Back to your regularly scheduled post
Keep calm and carry on
81 SH Something Special
79 SF MEAUQABEAUXS
81SH Nor'eas tah (Old Red)
80 LG Black Magic
78 E Standard Practice
James 3:17
“Alis Volat Propriis”
Yamaha XS 1100 Classic
For those on FBComment
Thanks for your Service Kat. I was also Army, missiles. Interesting discussion. My bike is at 58,000 miles and I need to check the valve clearance again and this was a good reminder. I also need the second gear fix and I am also immune.
Dell82
Houston, TX
82' XJ1100J Maxim "LASERMAX"
SOLD 86' Kawasaki Voyager XII, 1200cc SOLD
SOLD 82' CB450SC Nighthawk, FOR SALE SOLD
SOLD 82' CB450SC Nighthawk, parts bike SOLDComment
MP Tool Modification Needed - But worked GREAT
I found and read almost this entire thread before trying to use the MP tool today. I had played with it last week a little bit but thought there was something I was doing wrong. My MP tool WOULD contact the cam and would not engage properly until I ground a bit off of it with a die grinder as others had to do and mentioned earlier in this thread. Once I had the proper clearance on the MP tool I was able to change shims in all eight valves and double-check everything in about two hours.
I think there must be some inconsistency in the tools manufacture but it's still a indispensable tool to have.
Sincerely,
KurtKurt Boehringer
1982 - CBX1000 - Honda
2016 - FJR1300A - MontgomeryComment
