moving along, next step
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Scuba
    Yep, if you got a scuba tank, 2600 psi at your service, might just turn your motor into a cannon
    Originally posted by ddragon63
    Either way I don't think I personally would want to run it after breaking it free. It's locked up for a reason. I personally would try compressed air first before laying a mass amount of pressure to it. Btw theres ways of getting compressed air sources a lot higher than 250 psi.
    Just trying to give a fella options...
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      +1 to both of you guys, like I said earler, "IF" the bike was running when parked inside for 10 years, the motor is not rusted frozen. The only motors I have seen rust frozen are marine inbord boat motors that had the exaust heat exchangers rust through and then fill the jugs with salt water You may have been lied to, if it is seazed, it burned up with no oil in it and he filled it back up to sell it
      +1 on what Steve is saying. My xs was parked for 7 years in a uninsulated wood shed in sw Washington... It ran when it was parked in there. I changed the oil, pull the plugs, sprayed some seamfoam deep creep in the holes, dropped a little oil on top of that to lube the cylinder. Hooked the jump box to it and it rolled right over. Put plugs in it added some seamfoam to the oil in the case added gas to tank and lit fire to it. Of course ymmv. I knew mine ran previous to storage cuz I rode it in there.
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
      • ddragon63
        • Jan 2012
        • 1101
        • Ridgefield, WA
        Lmao... I was thinking nitrogen! Not sure is want to introduce compressed breathing air to on oily cylinder under pressure. It'll unstick the piston. But then you may be finding pieces of it for days! Oxygen+petroleum+pressure=combustion.
        I got a 6000 psi nitrogen bottle sitting here on the cylinder dock if you really need some pressure
        Don
        old:
        1989 kawi ex500
        1996 yzf-r6
        1999 yzf-r1
        2001 kawi zx-6r
        2000 Ducati 748
        2002 YZF-R1
        2005 V-Star 1100 Classic
          • 7785
          OK guys. I have a stuck one at the house. It's an XS650 but that shouldn't make a difference. I bought it in a junk yard for $30, locked up tight. I go home on the 4th. I'll try to make time to grease gun break it when I get home and tell you how easy it was.
          • Sparkett
            • 12
            • Spring Hill, Florida
            #35
            DING!! you got it!
            No battery yet, well the one on her is a gonner..just wanting to see if the one is as gummed together as the one carb was, kinda a set???
            Originally posted by Lonerider62
            Am I reading you correctly and you are trying to determine if your engine is frozen in a cylinder or two and trying to break it free?
            • XS1100_OEM4ME
              • Mar 2009
              • 1619
              #36
              Different
              Thats a different animal,, ball bearings, not like the 1100's. If your motor is frozen, most likley its in the jugs as the bearing very rarly freeze on those. 1100's bearings can spin, causing rattle, then total failure, or, weild to the crank, causing a seized motor
              1980 XS1100 Special
              1990 V Max
              1982 KZ750 LTD Twin
              1974 CB750-Four
              Past/pres Car's
              • XS1100_OEM4ME
                • Mar 2009
                • 1619
                #37
                Na
                Na, scuba tanks are filled with compressed air, not O2, so it is safe, but 2600 psi will send the piston flying all by its self
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                • ddragon63
                  • Jan 2012
                  • 1101
                  • Ridgefield, WA
                  #38
                  That would be my concern on a stuck motor that i have no real prior history on. Ran out of oil (due to various reasons too long to list) and the crank, bearings, and rods and or mains have joined in an unholy union..... which if that is the case you can put whatever pressure system you want to it and your gonna break or bend something. Take your pick of parts that will give first. Most liely blow your threaded pressure hose and plug threads straight @ you...
                  As my companies safety advisor I would like to take this moment to remind you to please have your safety glasses on while conducting this experiment
                  Don
                  old:
                  1989 kawi ex500
                  1996 yzf-r6
                  1999 yzf-r1
                  2001 kawi zx-6r
                  2000 Ducati 748
                  2002 YZF-R1
                  • ddragon63
                    • Jan 2012
                    • 1101
                    • Ridgefield, WA
                    #39
                    If you wanna get technical scubas are filled with compressed breathing air. Which is "suppose" to contain as much o2 as the air out side we breath. Which I'm sure we all know how a diesel works... Air, pressure, oil, bang. Either way 2600 by its self will turn the rod into a question mark....
                    Don
                    old:
                    1989 kawi ex500
                    1996 yzf-r6
                    1999 yzf-r1
                    2001 kawi zx-6r
                    2000 Ducati 748
                    2002 YZF-R1
                    • XS1100_OEM4ME
                      • Mar 2009
                      • 1619
                      #40
                      Joke
                      It was a joke Dragon, I hope everyone knows better then to apply 2600 psi of anything to any piston in a cyl, thus the canon referance
                      1980 XS1100 Special
                      1990 V Max
                      1982 KZ750 LTD Twin
                      1974 CB750-Four
                      Past/pres Car's
                        If you did it right, a set of Wiseco pistons would just drop in without doing any of that pesky machine work.
                        • ddragon63
                          • Jan 2012
                          • 1101
                          • Ridgefield, WA
                          #42
                          Broken pistons make good xmas gifts for smokers.
                          Don
                          old:
                          1989 kawi ex500
                          1996 yzf-r6
                          1999 yzf-r1
                          2001 kawi zx-6r
                          2000 Ducati 748
                          2002 YZF-R1
                          • Mathh
                            • Nov 2006
                            • 668
                            • Beek, Netherlands
                            #43
                            Have U tried disassembling the middle gear just to check if maybe this part has seized solid?
                            MV Agusta Brutale 910R '06.
                            Yamaha MT-09 Tracer '15 grey.
                            • XS1100_OEM4ME
                              • Mar 2009
                              • 1619
                              #44
                              Neutral
                              Should still turn over in neutral though
                              1980 XS1100 Special
                              1990 V Max
                              1982 KZ750 LTD Twin
                              1974 CB750-Four
                              Past/pres Car's
