Uni Air Filter
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Beautiful
    Hope it never happens, beautiful bike. the dreaded "OCTY" has saved many a bike, I guess thats why Yamaha put it on them
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    • JasonRedbeard
      • 109
      • Tuscaloosa, AL
      Hey I was wondering about that.....what the hell does that thing do, anyway?
      My Special is as old as I am.
      • mjpxs11sh
        • Jan 2011
        • 299
        • N/E, Illinois
        the octy is a vacuum operated diaphram that allows fuel to flow when the motor is creating vacuum and the petcock is in the run/res position. its on top of #2 carb. fuel doesnt flow when the motor is off.the carbs on these bikes are known to leak after sitting unattended for a while. this year i drained the carbs.
        i had a sticky float and my air box filled with fuel and ruined my air filter. what year is your Special Jason? nice SH Gary. dont see too many that color.
        Max
        81 XS1100SH Black Beast Mutt
        Kerker 4/1
        stock carbs and air box.
        78 headlite, handle bars,
        1 set of ea-160/85mph guages,
        crash bars, cruise control
        Other 2 Wheelers
        78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
        94 CBR1000F jet kit,Two Bros pipe, K&N Filter
        • JasonRedbeard
          • 109
          • Tuscaloosa, AL
          #34
          She's a 79SF, and I've had her for about 10 days. I found the octy (which I identified as such by the fact that it vaguely resembles an octopus) when I pulled the carb bank to tear them down for cleaning.
          • XS1100_OEM4ME
            • Mar 2009
            • 1619
            #35
            79sf
            Mine is a 79SF also, the octy (when working properly) can save the day, but it does not do anythhing if set to "prime" Never, leave your bike on "prime" if not running
            1980 XS1100 Special
            1990 V Max
            1982 KZ750 LTD Twin
            1974 CB750-Four
            Past/pres Car's
              • 5050
              #36
              Originally posted by mjpxs11sh
              i just received the Uni Filter and was very dissapointed at the quality and fit. no instructions, just a piece of xerox paper stating "must oil before use". has an internal non removeable cage sorrounded by yellow foam. got it to fit snugly into the bottom of the air box with lots of bending. oiling it and fitment will be a PITA. im gonna try returning it and get a paper OEM style replacement.
              I was VERY disappointed with the 78 E models airbox, because the keeper clips wound-up in the foam. I had to cut the filters with a Gin-soo (sp?) knife while prying the airbox open a bit. Let me tell you that foam is tough. I was quite pissed.
              • XS1100_OEM4ME
                • Mar 2009
                • 1619
                #37
                Octy
                IMHO, leave the octy in place, you can check it by sucking on the vac line and seeing if gas flows, then stops when you stop sucking. It is an easy rebuild if needed and comes with the dia. in many petcock kits. Way better then sending us pictures of your bike after it burned to the ground, or asking how to replace the crank bearings because gas got in your oil l
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
