Uni Air Filter
  • mjpxs11sh
    • Jan 2011
    • 299
    • N/E, Illinois
    Uni Air Filter
    my 81sh is in need of an air filter replacement. i found one constructed of reuseable foam called a Uni Filter for a better price for a paper element OEM replacement. i have a Kirker 4/1 exhaust i purchased 10yrs ago because it stated no carb rejetting necessary. my bike runs great with the Kirker and has a paper OEM air filter. but will i need to rejet when using a foam filter. Uni Filter has no stats other than to oil it before installation. im sure theres less air restriction thus more intake air. any help will be greatly appreciated. ive had the carbs on/off and made adjustments several times after sitting with 10yrs of bad fuel and finally have them where i want them. then again, i wouldnt mind a reuseable better airflow, better fuel mileage, air filter, but without having to rejet. someone please set me straight.
    Max
    81 XS1100SH Black Beast Mutt
    Kerker 4/1
    stock carbs and air box.
    78 headlite, handle bars,
    1 set of ea-160/85mph guages,
    crash bars, cruise control
    Other 2 Wheelers
    78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
    94 CBR1000F jet kit,Two Bros pipe, K&N Filter
    The UNI filter is a common replacement, and no jetting changes are required...
    • mjpxs11sh
      • Jan 2011
      • 299
      • N/E, Illinois
      thanx CS. ive had all the usual carb issues and could remove them with my eyes closed its been so many times. i def wanted to avoid pulling them again since ive got em right. dont fix what aint broken kinda thing. should have posted first cause i cancelled my Uni Filter order after i was reading google posts. oh well. i also checked with Yamaha for an OEM filter. they want $49 for it. unbelievable, what thieves.
      Max
      Kerker 4/1
      Other 2 Wheelers
        Just keep an eye on your plugs after you put it in. You could always be on the edge of running lean and the filter just might put it over the top. Better safe than sorry.
          • 8766
          A problem I had with a Uni foam filter a while back:
          The carbs weren't set up perfectly and the engine would like to backfire thru the carbs once in a while. Several months later I went to remove the air filter and it had caught on fire and melted. Only downside to these foam filters is they can melt and cause a mess in the air box if there is a problem. JMHO, YMMV.
          07 Triumph Tiger 1050
            • 9980
            I have them in both bikes. They work just fine for me.
            The one in the okieSPECIAL I've had in there for 3 years now. Clean and re-oil about twice a year. I just use spray lube to oil it.
              • 7859
              I have 4 into 1 exhaust and a K&N filter in the stock airbox. My jetting is stock. It looks to be the proper setup.
              • XS1100_OEM4ME
                • Mar 2009
                • 1619
                • Fort Myers, Florida
                Air filter
                Here is a reasonable replacment filter that is close to OEM
                OEM at a discount:
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                • daveyg
                  • Feb 2009
                  • 411
                  • Boise, ID
                  I put a UNI in my XJ650 and wow! the difference was like night and day! Going from clogged up paper filter to that thing u better be ready to hang on!
                  BARE BONES CHOPPERS: If it don't make it go faster, you don't need it!
                  80 XS1100SG(cafe in progress *slowly)
                  • DAVINCI
                    • Jan 2011
                    • 1048
                    • Cedar Mountain, NC
                    I can also vouch for the UNI, had mine about 6 yrs and as long as you keep it oiled, it won't deteriorate.
                      I can also vouch for the UNI, had mine about 6 yrs and as long as you keep it oiled, it won't deteriorate...................+1 on the UNI and have had for same amount of time. Careful of buying one of those NOS originals with the foam. Saw a thread here where a member had the foam come apart from its age and long shelf life.......JAT.
                      • tom clisham
                        • Sep 2010
                        • 627
                        • Northern Illinois
                        Uni products
                        I've got UNI in one bike & K&N in another. can't tell difference in performance. Like the UNI.
                        Also anyone looking for pod filters should look at the UNI website. Theirs are much superior to EMGOs & don't cost that much more.
                        Tom Clisham
                        Age is relative YOU WON"T GET OLD TIL YOU SELL THE BIKE
                        _____________________________________________
                        '78xs1100E ,all stock & original GONE TO WISCONSIN
                        '80 SG Vetter fairing,hard bags,trunk,fork brace,
                        stock headers with fishtail mufflers,black & beautiful GONE TO ARIZONA
                        79SF lowered,jardine 4/2 exhaust,pod filters,drilled rotors,fork brace, bar hopper
                        79SF 1 owner,8000 miles, restoring to completely original ( I hope) GONE TO FRANCE
                        • mjpxs11sh
                          • Jan 2011
                          • 299
                          • N/E, Illinois
                          thanx everyone. i guess ill be putting it in since i was just notified my order cant be cancelled. i feel i made the right choice after reading all the replys. what oil are you guys using for the filter. i have some K&N red oil spray for thier filters. will that be sufficient or do i need to soak it in motor oil? im hoping ill have to hang on when i grab a handfull.
                          Marty, great to hear you got your leaking carbs straight, was reading your post last night. ive had that among the other typical carb issues.
                          Max
                          Kerker 4/1
                          Other 2 Wheelers
                          • XS1100_OEM4ME
                            • Mar 2009
                            • 1619
                            K&n
                            I would guess the K&N spray would be fine, but it should come with instructions as to what kind of oil is compatabule with their foam, I would check to be sure
                            1980 XS1100 Special
                            1990 V Max
                            1982 KZ750 LTD Twin
                            1974 CB750-Four
                            Past/pres Car's
                            • DAVINCI
                              • Jan 2011
                              • 1048
                              UNI has their own oil, but you could use motor oil. If you do, get a heavy weight oil so it sticks. The K&N stuff should be fine, too. I bet it's pretty sticky stuff, eh?
                              Wring it out when you're done oiling it. If it's too wet, it'll drip on the motor. DAMHIKIJK
