Uni Air Filter
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Oil
    Hey, if your carbs do what mine have in the past, it won't matter what kind of oil you use on your air filter, it will be washed of with gas soon
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
    • daveyg
      • Feb 2009
      • 411
      • Boise, ID
      I highly recommend No-Toil Air filter oil. Used it with my UNI on the XJ650, and also use it in all my dirt bikes, it is the best stuff I have ever used, and extends the life of your filters, since u won't have to use solvent to clean them next time. No-Toil can be washed out with warm water and dish or hand soap.
      BARE BONES CHOPPERS: If it don't make it go faster, you don't need it!
      80 XS1100SG(cafe in progress *slowly)
      • petejw
        • 2269
        • sydney australia
        ive been using the uni pod filters
        with the original v stax from the airbox
        stuffed inside for years with really ggod results.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          Jack Daniels
          You type like me, My excuse is Jack Daniels made me do it
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
          • Lonerider62
            • Nov 2011
            • 187
            • Gaylord, MI.
            I've used stock, K&N's, UNI's and a few other reusable/washable filters and found that there is very little difference when comparing a clean, stock filter to a clean, washable type. When I had my Triumph Speedmaster, a member of the Rat did a test of the actual filtration attained with different types of filters and when the dust settled, hands down the original pleated filters filtered out the finest particles and had flow rates equal to or even higher than the aftermarket filters. Where the K&N's and other reuseable filters hold an edge is the ability to clean and reuse them for 0$. My FZ1 uses a stock filter that's about $30 so having a K&N does save me a few bucks even if I only reuse it once. If I lived in a place like Arizona where fine dust is an issue, I probably wouldn't use anything other than an OEM because replacing a bank of cylinders on the FZ is EXPENSIVE.
            Can't beat the smell of gas & oil
            • XS1100_OEM4ME
              • Mar 2009
              • 1619
              +1, that is why I add a link to a disposable OEM kind of filter when a member is looking Just blow them out once or twice (depending on your location) Cheap, fast and reliable
              Originally posted by Lonerider62
              I've used stock, K&N's, UNI's and a few other reusable/washable filters and found that there is very little difference when comparing a clean, stock filter to a clean, washable type. When I had my Triumph Speedmaster, a member of the Rat did a test of the actual filtration attained with different types of filters and when the dust settled, hands down the original pleated filters filtered out the finest particles and had flow rates equal to or even higher than the aftermarket filters. Where the K&N's and other reuseable filters hold an edge is the ability to clean and reuse them for 0$. My FZ1 uses a stock filter that's about $60 so having a K&N does save me a few bucks even if I only reuse it once. If I lived in a place like Arizona where fine dust is an issue, I probably wouldn't use anything other than an OEM because replacing a bank of cylinders on the FZ is EXPENSIVE.
              1980 XS1100 Special
              1990 V Max
              1982 KZ750 LTD Twin
              1974 CB750-Four
              Past/pres Car's
              • mjpxs11sh
                • Jan 2011
                • 299
                • N/E, Illinois
                ha ha OEM4me. let me tell ya, been there done that. thats why im not in the mood to mess with em if its not nec, know what i mean:rolleyes
                Max
                81 XS1100SH Black Beast Mutt
                Kerker 4/1
                stock carbs and air box.
                78 headlite, handle bars,
                1 set of ea-160/85mph guages,
                crash bars, cruise control
                Other 2 Wheelers
                78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
                94 CBR1000F jet kit,Two Bros pipe, K&N Filter
                • mjpxs11sh
                  • Jan 2011
                  • 299
                  • N/E, Illinois
                  i just received the Uni Filter and was very dissapointed at the quality and fit. no instructions, just a piece of xerox paper stating "must oil before use". has an internal non removeable cage sorrounded by yellow foam. got it to fit snugly into the bottom of the air box with lots of bending. oiling it and fitment will be a PITA. im gonna try returning it and get a paper OEM style replacement.
                  Max
                  Kerker 4/1
                  Other 2 Wheelers
                  • DAVINCI
                    • Jan 2011
                    • 1048
                    • Cedar Mountain, NC
                    IDK what you got, but my UNI has removable foam, it wraps around from inside the cage and folds over the outside. So far it's lasted four times the life of my last OEM filter.
                      Yeah, the wire cage gets flattened in shipping and takes a little massaging to get shaped properly. Ain't no thang.
                      Take the foam off and use your old paper filter as a template to shape the wire.
                      • mjpxs11sh
                        • Jan 2011
                        • 299
                        • N/E, Illinois
                        thanx DAVINCI! now i see the foam comes off the cage. now oiling it makes sense. duh on my part. live and learn. thanx to all! i guess ill see how it works when the riding season returns.
                        Max
                        Kerker 4/1
                        Other 2 Wheelers
                        • GaryF
                          • Mar 2009
                          • 54
                          • South Berwick Maine
                          XS1100 OME4ME be very careful with the gas leaking from carbs into airbox or pods. A buddy of mine had some gas in his airbox and when he reved his bike it backfired into the box and burned his bike
                          Before fire
                          And after
                          Gary
                          1100SH The Chosen one
                          Honda XR650L The Muddy one
                            • 8077
                            I almost burned mine up the same way. I would have, had my daughter not been there and been so quick with a fire bottle.
                            • XS1100_OEM4ME
                              • Mar 2009
                              • 1619
                              It already happened!!!
                              It already happened to my XS1100
                              That was my 1st XS1100, burned to the ground at a shop before I ever got to ride it. I had just had them completly rebuild the motor, new clutch, all new parts
                              Fortunitly, the owner was honest and paid for my current XS1100
                              1980 XS1100 Special
                              1990 V Max
                              1982 KZ750 LTD Twin
                              1974 CB750-Four
                              Past/pres Car's
                              • GaryF
                                • Mar 2009
                                • 54
                                Wow looks like an epidemic
                                I was moving mine two years ago, and thought I smelled gas.
                                I look on the engine and gas is dripping out of the airbox
                                Come to find out the airbox was as full as it could be and a substantial amount had also leaked into my crankcase
                                So now I give it a shake and a sniff before I start it up
                                I'd really hate to burn my baby!
                                Gary
