genuine PineSol worked fine for me
Hi,
Pine sol has worked for me and others, along with other products. I didnt get sparkling clean on the outsides, but the insides and parts were useable. I used a much larger tub and completely immersed carbs. It took four quarts of genuine pinesol. I think the generic stuff thats called pine cleaner, may be adulterated with who knows what.
I have had real good luck with the yammie cleaner, half and half in water in a large coffee can, soaking three, then the next day turn over and soak the other end after washing everything up well with hot water.
All three of those little tiny holes near the throttle plate, MUST FLOW, and also the tiny hole in the back of the bowl, MUST flow thru to spray or air. I used cheapo carb cleaner in a spray can to actually clean the metal thru the jets and jet mounts. I found that hi pressure air prolly works just as well for that though.
Hi,
