Can Cold Weather cause my engine to die if I dont keep gasing it? Its below 0 degrees Celcius and im using 20-50 motor oil. When I give her alot of gas she seems to run fine its just whenever Im in the middle of traffic and let off the throttle she wants to die. CARS IN FRONT OF ME CARS BEHIND ME, DANG!!!!
Motor dying in the middle of traffic :(
Cold Temperatures
For my 79F it is recommended that a lighter oil (I believe 10W-40) be used below 40 degrees Farenheit.
Also, at these lower temperatures, the pilot circuit could be running lean (colder air is denser air). Go somewhere there is little traffic. As you come to a stop, I would pull out the choke lever one notch and see if the bike runs better. This serves to enrichen the mixture. If it runs better then I would say that it definitely is running too lean. If I recall correctly, turning the pilot screws out enrichens the mixture of the pilot circuit. You could do a thread search to confirm this.
Usually if you tinker with the settings on the carbs, you have to resync them.
Good Luck . . . hope this helps!1979 F
Mac 4-2 Exhaust
T-Kat Fork Brace
Spade Fuse Box Mod
Stainless Steel Braided Brake Lines
140.0 Main Jets
45.0 Pilot Jets
266 X-2 Needle Jets
Extreme cold weather can keep an engine from reaching optimum operating temperature, and could therefore need a richer mix to keep running. Also having read your carb tuning problems threads, that until you get the engine and carbs well tuned, it can be hard for it to maintain a good idle even when the weather is warm! You may want to just turn up the idle speed screw a bit to keep it running a little faster when you release the throttle while you're out there in the cold air!
T.C.T. C. Gresham
u could also try running a hotter range plug,
try a bp5es.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
No, if your bike is dieing at idle, it is not the cold weather. Cold weather will require a longer warm up time with the choke on, but once at opperating temp, it will idle fine if all else is correct. Your carbs are causing the problem. I would make sure that the emulsion tubes are crystal clean, and the jets also. Next, I would set the floats to the higest spec. for your bike. Make "SURE" no fuel mix screw tip is broke off in the carb body, then start at 2 1/4 turns out, that is rich, but you can tune down and will help with warm up in your cold temp's. Sync the carbs with your gauge and the valves I told you about and set your idle at around 1200 RPM. If your carbs are realy clean (especialy the emulsion tubes) and you have good fuel flow to them (ie, no lines going down below the bowl hight then back up). After you have it idleing right you can turn the fuel mix screws in 1/4 turn each, then ride for a while and do it again till the idle drops slightly, then back out 1/8th turn, should be good
Originally posted by anarchy18 View PostCan Cold Weather cause my engine to die if I dont keep gasing it? Its below 0 degrees Celcius and im using 20-50 motor oil. When I give her alot of gas she seems to run fine its just whenever Im in the middle of traffic and let off the throttle she wants to die. CARS IN FRONT OF ME CARS BEHIND ME, DANG!!!!1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
Originally posted by geobiker View PostFor my 79F it is recommended that a lighter oil (I believe 10W-40) be used below 40 degrees Farenheit.
Good Luck . . . hope this helps!'81 Yamama XS1100 5K7 German Model
What's the difference between erotic and kinky?
Erotic = using a feather
Kinky = using the whole chicken
Originally posted by TopCatGr58 View PostExtreme cold weather can keep an engine from reaching optimum operating temperature, and could therefore need a richer mix to keep running. Also having read your carb tuning problems threads, that until you get the engine and carbs well tuned, it can be hard for it to maintain a good idle even when the weather is warm! You may want to just turn up the idle speed screw a bit to keep it running a little faster when you release the throttle while you're out there in the cold air!
ILL TRY THAT TC!!!! I just put that heavy oil in not too long ago and its not helping the problem im sure'81 Yamama XS1100 5K7 German Model
Originally posted by Shacknasty View PostSynch, adjust A/F mix screws and synch again.'81 Yamama XS1100 5K7 German Model
Originally posted by petejw View Postu could also try running a hotter range plug,
try a bp5es.'81 Yamama XS1100 5K7 German Model
jat, our carbys are different on the sports bike
compared to the 81 us spec xs,
we have 40 pilots without bleed holes
and different emulsion tubes with adjustable needles,
what clip setting have u set the slides at?pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
Mine have adjustable needles also79SF USAOriginally posted by petejw View Postjat, our carbys are different on the sports bike
what clip setting have u set the slides at?1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
Originally posted by XS1100_OEM4ME View PostMine have adjustable needles also79SF USACy
Moron
You are so correct Sir, I am a Moron, how could I have missed that, of course the Year matters I only have one year now 1979 I apoligize for being so dumb I will stop trying to help others as it is clear I am stupid
Originally posted by cywelchjr View PostYes, but U.S. bikes after 79 don't have adjustable needles. 79 was the last year with adjustable needles in the U.S. at least in stock form. This is why the year matters, there are a LOT of differences between the different models and years, some minor and some pretty major. (more minor ones than major ones though)1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
the carb bodies are the same for all the 81 models,
ours are just jetted differently.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
