Motor dying in the middle of traffic :(
  • anarchy18
    • Sep 2011
    • 134
    • Germany
    Can Cold Weather cause my engine to die if I dont keep gasing it? Its below 0 degrees Celcius and im using 20-50 motor oil. When I give her alot of gas she seems to run fine its just whenever Im in the middle of traffic and let off the throttle she wants to die. CARS IN FRONT OF ME CARS BEHIND ME, DANG!!!!
    '81 Yamama XS1100 5K7 German Model
    What's the difference between erotic and kinky?
    Erotic = using a feather
    Kinky = using the whole chicken
  • geobiker
    • Mar 2010
    • 82
    • Pa
    Cold Temperatures
    For my 79F it is recommended that a lighter oil (I believe 10W-40) be used below 40 degrees Farenheit.
    Also, at these lower temperatures, the pilot circuit could be running lean (colder air is denser air). Go somewhere there is little traffic. As you come to a stop, I would pull out the choke lever one notch and see if the bike runs better. This serves to enrichen the mixture. If it runs better then I would say that it definitely is running too lean. If I recall correctly, turning the pilot screws out enrichens the mixture of the pilot circuit. You could do a thread search to confirm this.
    Usually if you tinker with the settings on the carbs, you have to resync them.
    Good Luck . . . hope this helps!
    1979 F
    Mac 4-2 Exhaust
    T-Kat Fork Brace
    Spade Fuse Box Mod
    Stainless Steel Braided Brake Lines
    140.0 Main Jets
    45.0 Pilot Jets
    266 X-2 Needle Jets
      Extreme cold weather can keep an engine from reaching optimum operating temperature, and could therefore need a richer mix to keep running. Also having read your carb tuning problems threads, that until you get the engine and carbs well tuned, it can be hard for it to maintain a good idle even when the weather is warm! You may want to just turn up the idle speed screw a bit to keep it running a little faster when you release the throttle while you're out there in the cold air!
      • petejw
        • 2269
        • sydney australia
        u could also try running a hotter range plug,
        try a bp5es.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          • Fort Myers, Florida
          No, if your bike is dieing at idle, it is not the cold weather. Cold weather will require a longer warm up time with the choke on, but once at opperating temp, it will idle fine if all else is correct. Your carbs are causing the problem. I would make sure that the emulsion tubes are crystal clean, and the jets also. Next, I would set the floats to the higest spec. for your bike. Make "SURE" no fuel mix screw tip is broke off in the carb body, then start at 2 1/4 turns out, that is rich, but you can tune down and will help with warm up in your cold temp's. Sync the carbs with your gauge and the valves I told you about and set your idle at around 1200 RPM. If your carbs are realy clean (especialy the emulsion tubes) and you have good fuel flow to them (ie, no lines going down below the bowl hight then back up). After you have it idleing right you can turn the fuel mix screws in 1/4 turn each, then ride for a while and do it again till the idle drops slightly, then back out 1/8th turn, should be good
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
          • Shacknasty
            • Feb 2011
            • 379
            • SFV-SoCal
            Synch, adjust A/F mix screws and synch again.
            • anarchy18
              • Sep 2011
              • 134
              • Germany
              Engaging the choke was the first thing I tried and almost choked on gas fumes and my eyes watered etc after that and it didnt really help her stay running any better either.
              • anarchy18
                • Sep 2011
                • 134
                • Germany
                ILL TRY THAT TC!!!! I just put that heavy oil in not too long ago and its not helping the problem im sure
                • anarchy18
                  • Sep 2011
                  • 134
                  • Germany
                  You synch before u adjust and then synch again? Good to know Is the pilot and a/f screw the same thing? Can u give me a simple run down how to adjust on the XS1100?
                  • anarchy18
                    • Sep 2011
                    • 134
                    • Germany
                    try a bp5es.
                    Never thought about HOTTER PLUGS for the winter I might try that also, YOU GUYS ARE JUST SO FULL OF IDEAS.....Thank You
                    • petejw
                      • 2269
                      • sydney australia
                      jat, our carbys are different on the sports bike
                      compared to the 81 us spec xs,
                      we have 40 pilots without bleed holes
                      and different emulsion tubes with adjustable needles,
                      what clip setting have u set the slides at?
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
                      • XS1100_OEM4ME
                        • Mar 2009
                        • 1619
                        Mine have adjustable needles also79SF USA
                        1980 XS1100 Special
                        1990 V Max
                        1982 KZ750 LTD Twin
                        1974 CB750-Four
                        Past/pres Car's
                          Yes, but U.S. bikes after 79 don't have adjustable needles. 79 was the last year with adjustable needles in the U.S. at least in stock form. This is why the year matters, there are a LOT of differences between the different models and years, some minor and some pretty major. (more minor ones than major ones though)
                          • XS1100_OEM4ME
                            • Mar 2009
                            • 1619
                            Moron
                            You are so correct Sir, I am a Moron, how could I have missed that, of course the Year matters I only have one year now 1979 I apoligize for being so dumb I will stop trying to help others as it is clear I am stupid
                            1980 XS1100 Special
                            1990 V Max
                            1982 KZ750 LTD Twin
                            1974 CB750-Four
                            Past/pres Car's
                            • petejw
                              • 2269
                              • sydney australia
                              the carb bodies are the same for all the 81 models,
                              ours are just jetted differently.
                              pete
                              new owner of
                              08 gen2 hayabusa
                              former owner
                              zrx carbs
                              18mm float height
                              145 main jets
                              38 pilots
