Carbon Fouled
Your are discribing carbon fouled plugs, a hotter plug could help, especialy consiidering your location. Also, check your coil output is OK. If your air filter is good and clean, your mix screws might be set to rich, The more time you idle the more this will build up on your plugs if running to rich a setting on your mix screws
