I know someone was saying using metal hardware on a fairing windshield is bad but I can't find it. What is wrong with using metal bolts to hold the windshield on a fairing?
Metal Hardware on a Fairing Windshield?
Theodore RooseveltTags: None
If the windshield is attached with metal bolts and blind nuts, and something hits the windshield, then the nuts/bolts tear-out of the fairing (I have one that that happened to). Plastic bolts will shear-off can be easily replaced.
In my case I had the windshield mounting area replaced from another fairing using plastic welding. Basiclly using 2 junk fairings to make one good one.Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
Besides that, the metal bolts don't have any 'give' in them and you can develop cracks radiating out from the mounting points. If you put some sort of rubber grommets around the bolts they'll work.Fast, Cheap, Reliable... Pick any two
Plastic bolts
http://www.google.com/search?source=...w=1280&bih=598
Originally posted by DCracer25 View PostWhere can you get the plastic bolts and nuts for the windshield? I need to replace mine.1979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
Most any hardware store will have nylon screws or bolts...Fast, Cheap, Reliable... Pick any two
Cant find under XS1100, but some of these should work, just chack size
http://www.google.com/search?source=...w=1280&bih=5981979 XS1100 Special (Mad Max, OEM) Current
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
Unfortunately, the plastic/nylon screws and bolts from the hardware store are NOT the same quality as ones you can get from Vetter's web site. Oh, they'll work, but WILL pull apart from vibration and load forces. The set from Vetter, being of better quality uses metal nuts on the screws and can be pulled fairly tight. Hardware store quality nylon screws and bolts should be considered a temporary fix at best. JAT, and based on my experience.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
To answer the question, the real reason for the plastic bolts is rider safety. If you crash, and your body hits the windshield, you want the windshield to break away. The plastic bolts and the clips are an intentional weak point that will allow the shield to break away if your body hits it from behind, instead of holding it fast, creating a guillotine.1980 XS850SG - Sold
$8.95!!!
Here is a set for $8.95 FREE S/H
http://compare.ebay.com/like/1405940...=sbar&_lwgsi=y
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
Does Vetter and Pacifico use the same screws?Nathan
fairly sure they do Nate.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
I have had pretty good luck from the nylon bolts from Lows. Yeah, sometimes they do break, but they are cheap and available. PS, the standard bolts up high, left and right, are metal and are installed through a metal U-clip.Skids (Sid Hansen)
Anyone certain about vetter and pacifico using the same hardware?Nathan
Originally posted by natemoen View PostAnyone certain about vetter and pacifico using the same hardware?Fast, Cheap, Reliable... Pick any two
