Metal Hardware on a Fairing Windshield?
    I know someone was saying using metal hardware on a fairing windshield is bad but I can't find it. What is wrong with using metal bolts to hold the windshield on a fairing?
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    If the windshield is attached with metal bolts and blind nuts, and something hits the windshield, then the nuts/bolts tear-out of the fairing (I have one that that happened to). Plastic bolts will shear-off can be easily replaced.
    In my case I had the windshield mounting area replaced from another fairing using plastic welding. Basiclly using 2 junk fairings to make one good one.
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
      Besides that, the metal bolts don't have any 'give' in them and you can develop cracks radiating out from the mounting points. If you put some sort of rubber grommets around the bolts they'll work.
      • DCracer25
        • Jul 2011
        • 179
        • harpursville NY
        bolts
        Where can you get the plastic bolts and nuts for the windshield? I need to replace mine.
        • XS1100_OEM4ME
          • Mar 2009
          • 1619
          • Fort Myers, Florida
          Plastic bolts
          1980 XS1100 Special
          1990 V Max
          1982 KZ750 LTD Twin
          1974 CB750-Four
          Past/pres Car's
            Most any hardware store will have nylon screws or bolts...
            • XS1100_OEM4ME
              • Mar 2009
              • 1619
              Cant find under XS1100, but some of these should work, just chack size
              1980 XS1100 Special
              1990 V Max
              1982 KZ750 LTD Twin
              1974 CB750-Four
              Past/pres Car's
                Unfortunately, the plastic/nylon screws and bolts from the hardware store are NOT the same quality as ones you can get from Vetter's web site. Oh, they'll work, but WILL pull apart from vibration and load forces. The set from Vetter, being of better quality uses metal nuts on the screws and can be pulled fairly tight. Hardware store quality nylon screws and bolts should be considered a temporary fix at best. JAT, and based on my experience.
                  To answer the question, the real reason for the plastic bolts is rider safety. If you crash, and your body hits the windshield, you want the windshield to break away. The plastic bolts and the clips are an intentional weak point that will allow the shield to break away if your body hits it from behind, instead of holding it fast, creating a guillotine.
                  • XS1100_OEM4ME
                    • Mar 2009
                    • 1619
                    $8.95!!!
                    Here is a set for $8.95 FREE S/H
                    1980 XS1100 Special
                    1990 V Max
                    1982 KZ750 LTD Twin
                    1974 CB750-Four
                    Past/pres Car's
                      Does Vetter and Pacifico use the same screws?
                        fairly sure they do Nate.
                          • 5069
                          I have had pretty good luck from the nylon bolts from Lows. Yeah, sometimes they do break, but they are cheap and available. PS, the standard bolts up high, left and right, are metal and are installed through a metal U-clip.
                            Anyone certain about vetter and pacifico using the same hardware?
                              Nate, the ones I have here do (1/4-20 screws), but that doesn't mean they all do....
