xs1100 ignition
    Originally posted by Chadwic82
    which ones are those?
    Here you go...
    • Douglas Money
      • Jun 2006
      • 180
      • Braidwood IL
      Pickup coils are located on left side under cover. They tell the TCI unit to fire the coils. The wires break and they stop working. There is a fixit thread on here about them. Check for pickup coil wire repair and you can see what needs to be done. Easy job to test and fix.
      1979 XS1100F (runnin the wheels off it)
      1979 XS650 (ran the wheels off it)
      1976 CB550F (ran the wheels off it)
      • Douglas Money
        • Jun 2006
        • 180
        • Braidwood IL
        Phil types faster than me it looks like.
        • Chadwic82
          • Jul 2011
          • 20
          • Oklahoma City, OK.
          Thanks. I will try to look at it today.
          • Chadwic82
            • Jul 2011
            • 20
            Well, I tried the easy fix by replacing the TCI but the problem still exists. geuss I'll try the pickup wire fix when I get some more time. Took a visual look at them and they seem fine but I know looks can be deceiving.
            Thanks guys for all the help. It's greatly appreciated.
            • Douglas Money
              • Jun 2006
              • 180
              • Braidwood IL
              You can't see the broken wires, you need an ohm meter to tell. When you hook up the meter, move the wires and watch the meter. If it jumps around, you have broken wires.
              • DAVINCI
                • Jan 2011
                • 1048
                • Cedar Mountain, NC
                BTW, use an analog meter, the digital ones are too slow to react.
                • cywelchjr
                  XS-XJ Super Guru(Deceased)
                  • 4450
                  • Sacramento, CA
                  While there are digital meters that can be used for this type of troubleshooting, the normal person is not likely to have one of them, as they are on the pricey side of things. Even many electronic techs who have need of that type of troubleshooting will just get an analog meter to go with their digital rather than spend the money on a digital that can emulate an analog meter (as I said, you can find them, but unless you use them a lot it's not cost effective, and even then it's often more cost effective to just get an analog meter anyways, so that keeps them rare even so).
                  • Chadwic82
                    • Jul 2011
                    • 20
                    I've got both(electrician) When I get some free time I'll play with it and see if I can't trace it down.
                    • radical123
                      • Dec 2008
                      • 172
                      • salem or
                      coil
                      would that not be a bad coil?if you swap wires and get spark only from one coil.
                      Quote:Had spark on cyl. 1 and 4. 2 and 3 had nothing. Swapped the wires feeding the coils and 2 and 3 worked but 1 and 4 had nothing.End of quote:
                      Just thinking mabe you could try some one close to you to see if you could try a set of coil swap test. (BA80)
                      Good luck.
                      Radical Ron
                      1980 midnight xs1100 Rebilt cosmetically
                      1980 midnight xs850 bagger
                      1980 Special xs1100 (all apart)
                      1979 special Special runner
                      2011 street glide
                      • Chadwic82
                        • Jul 2011
                        • 20
                        Well I was finally able to mess with the bikeand couldn't find any bad wires. Tried a different TCI and did not fix it. Now I have no spark out of either coil using both TCI's. Also when I turned the ignition on I heard a sparking sound. Upon further inspection I noticed the spark plugs were getting an intermittant spark.?????????
                          key switch?
                            Engine left side-cover that has YAMAHA on it. Pull on each wire every inch holding other end.........if sheathing stretches, you found a break.........likely culprit........
                              Unscrew spark-plug end caps, corrosion found, cut back quarter inch and re-assemble.
                              • Chadwic82
                                • Jul 2011
                                • 20
                                It was sparking with just the key on. I Hadn't even touched the start button yet. I put the key in. Turned it to on and then it started sparking?
