xs1100 ignition
  • GLoweVA
    replied
    I've found the easiest way to do the compression test is to have all 4 plugs out and the tester in one hole. Less load on the starter this way and you don't have to hassle with pulling the plugs as you go.
    Also, it was way easier to do it with the carbs out, rather than trying to hold the throttle wide open.
    ps. take your time on those carbs. dirt is the enemy. keep the parts matched with which ones they came out with. Read and re-read the tech tips on these things. (it will only help in the long run)
    Ask lots of quesitons.
    you don't have to take the carbs apart from the bank to get them clean.
    Leave a comment:
  • XSLevi
    replied
    You said it. I threw up my arms in the victory "V" when she fired off. I'll hafta do the compression test. I can't keep her running for long enough to tell if she's firing all four or not. I've got the carbs apart right now trying to fix this problem.
    Leave a comment:
    replied
    If it ran smoothly on all 4 chances are good the valves are not bent. That's not 100%, but chances are good. If you have access to a compression tester it would be worth doing a compression test.
    It's really cool when they start for the first time, even if it's just the first time with a new engine in them.
    Leave a comment:
  • XSLevi
    replied
    I'm not entirely sure that there are not bent valves. I haven't had it running other than the very brief start last night, but in all the time that I've spent cranking on the starter, I havent heard anything that would indicate that.
    Leave a comment:
  • GLoweVA
    replied
    And the shop would have cpst you a pretty penny too.
    Wow, cam off by 60deg.
    It's amazing you didn't bend any valves.
    Keep going. You'll love it when you get her on the road.
    Leave a comment:
  • XSLevi
    replied
    Steve was right, exhaust cam was off by about 60 degrees. Got everything lined up (damn that was difficult!) & she fired off for the first time since I've had her! Only ran for about 2 seconds, but its good to see a little progress! Thank you to everyone who is sticking with this thread, without the help I would've turned her over to the shop long ago and would have learned nothing.
    Leave a comment:
  • XSLevi
    replied
    So uh, how do I do that? lol.
    I think you must be right about the cam timing as I can't figure out what else it could be. I've cheked the maintainance section, there seems to be very little thier in how to set up cam timing. Any advice is apprecitated.
    Leave a comment:
    replied
    Originally posted by XSLevi
    Steve, would a compression test tell me if I'm good on those issues? Seems to me that valve trian issues will affect compression. Do you know what kind of numbers I should be getting on a compression test?
    You'll find that 'good' compression numbers can be all over the map; the FSM specs 146 psi as 'nominal', but I've personally seen numbers as high as 200, and some have reported numbers as low as 100 psi and still had a decent-running bike. The reason I suggested this is if the cams are off only one tooth you'll still show good compression, but you will have issues with starting. If the cams and/or the cam chain have been disturbed/removed, it's pretty easy for them to 'jump time'.
    Valve lash can affect compression, but if you haven't checked any of this, it's a good time to do so; remember, the valve lash on these motors get tighter with wear, not looser, so adequate valve lash is critical...
    Leave a comment:
    replied
    Those MIGHT tell you, but other problems could affect those, and you could have problems with those and still have decent compression. You really need to get the manual and check the valve timing, cam chain tension (which is easy BTW) and the valve lash.
    Also, just in case, cause it can happen, swap the orange and grey wires on the primary side of the ignition coils and see if that makes it fire up. It's possible that the coils are 180 out and if so this will fix it. If this doesn't fix it, or makes it pop out the carbs, put it back the way it was before continuing any further, but I fought for two days with a not starting engine and then finally on someones suggestion did this and it fired on the first press of the starter button.
    Leave a comment:
  • XSLevi
    replied
    Leave a comment:
    replied
    ... On the 81, intead of slots, there are holes, which fix the assembly in a pre-determined position. Does anybody know how to set timing on this thing?
    As you noted, there is no adjustment on the '81. You simply install the pickup assembly and that's it; it's set.
    You might want to check cam timing, cam chain tension and valve lash if you haven't yet; if that's been messed with, that could be at least part of the problem...
    Leave a comment:
  • XSLevi
    replied
    SUCCESS!! (sort of)
    Finally, Cylinders 2 & 3 are firing! NOS P/U coil assembly cost 400.00 from speed & sport, so I decided to take a chance with a single P/U coil cut off of a salvage bike (30.00). Cut off the bad one & soldered the salvage piece in place. Bang! Bike is now firing all 4 plugs!
    I still have not been able to get the thing to start. While cranking, it will give a little rumble like it wants to catch, but just doesn't quite get there. I've tried priming the cylinders with gas, and even some starting fliud. No luck.
    I'm wondering if thefailure to start might be due to the timing being off, but I can't figure out how to set it on this bike. On earlier models there are slots where the P/U coil assembly bolts on to the crank case. Said slots allow for adjustment of the P/U coils relative to the position of the rotor. On the 81, intead of slots, there are holes, which fix the assembly in a pre-determined position. Does anybody know how to set timing on this thing?
    Leave a comment:
    replied
    Does anyone know if I can use P/U coils from an earlier bike? I understand that the unit is different w/ regard to mechanical advance, but I'm wondering if I can just rob the p/u coild themselves off off an earlier unit.
    The pickup coils themselves are all the same.
    Leave a comment:
  • XSLevi
    replied
    Leave a comment:
  • XSLevi
    replied
    Nate, I'm thinking it might be the coil itself. I've made teeney little slits in the insulation of the p/u coil wires right before they enter the plastic housing of the coil. Testing there for continuity across the coil gets me the infinity reading. However, If I check a single wire for continuity between the point where I made the slit, and up top at the corresponding pin, I get .05 or so Ohms. I think this means that the p/u coil itself is bad right? The good p/u coil shows something like .765 ohms ACROSS the coil. Is there any way to fix these?
    Leave a comment:
