xs1100 ignition
    replied
    If the voltage drops below 10.5 at the tci then the tci won't send the signal to fire anything.
    Leave a comment:
  • Chadwic82
    replied
    Welcome to the site, first off!
    I would start by looking at ALL the ground connections on the bike. Pay attention to the one from the battery to frame, and frame to engine. pull both , clean them, and reinstall with anti-seize compound around the connectors. The next one to fix is on the top of the Reg./Rectifier. There are about three black wires all connected to the screw, and they should be cleaned and installed with anti-seize on them.
    Make sure the battery is fully charged, and check the pick-up coil wires at the TCI box connection.
    Thanks for the welcome. Battery is new and has full charge,checked the wires at the TCI & I'm gaoing to check the grounds this weekend. Would the grounds cause just one coil not to fire? I would think you would lose both.
    Leave a comment:
    replied
    Leave a comment:
  • Chadwic82
    started a topic xs1100 ignition
    xs1100 ignition
    Hi everyone, Newbie here. My name is Chad Prater and I had some questions about the ignition box on my 1981 xs 1100. I tried to fix it by re-soldering the connections but still have the same problem. When I read with a multi-meter on the orange wire, it starts out at 11 volts and goes between 2 and 4 volts when the starter is engaged. When I put the multi-meter on the gray wire, it starts at 11 volts and goes down to 8 when starter is engaged. Can anyone tell me if I have a bad ignition box or could it be something else? Thank you!
