vacuum lines?
  • Titbit21
    • Feb 2011
    • 76
    • Kent, Ohio
    vacuum lines?
    I reinstalled my carbs today but forgot a few things for where they go. The two lines coming off the 2 and 3 cylinder (i think) are they vacuum if so where do they plug into on the carbs. I was a having a poor time seeing with having no light, and i really didn't want to take them back off to look after wrestling them in there. any answers? Also is there anything else i might be missing. I have installed the fuel lines and the lines that run to the airbox, also a bigger line that plugged into the middle of the airbox thanks.
    '78E
    Each carb intake boot has a vacuum fitting on it. The outside two are capped in normal use, the inside two go to the tank petcocks...
    • mack
      • 2411
      • Ontario, Canada
      vents
      Being the older carbs, they could be the vent lines going to your air box. Picture would help.
      mack
      79 XS 1100 SF Special
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      https://youtu.be/wB5Jfbp6SUc
      https://youtu.be/RaI3WYHSuWA
      Frankford, Ont, Canada
      613-398-6186
        Don't forget the vacuum advance line ot the #2 carb nipple (on the carb body).
        • Titbit21
          • Feb 2011
          • 76
          • Kent, Ohio
          I did see that last night, what line runs to that? And on the petcocks which one is vacuum and which is fuel? thanks
          '78E
            The vac advance is the tube coming out the top of the timing cover on the left side of the bike. That tube connects to that port on the carb.
            • Titbit21
              • Feb 2011
              • 76
              • Kent, Ohio
              sweet thanks. you happen to know the petcocks? which one is for fuel and vacuum
              '78E
                The vacuum connects to the smaller of the two connections...
                • Titbit21
                  • Feb 2011
                  • 76
                  • Kent, Ohio
                  thanks steve. Another thing i have noticed, I hooked up the fuel lines, vacuum lines, the three lines to the air box, and the vac advance. My problem is i noticed another line sitting in there. It looked like maybe for draining or something. It was a line i have left there when i have removed the carbs. Is this needed and what is it?
                  Also the line thats connected to where the top mount of the air box, does that go to the tank? it looks like it was meant for that. But at this point i dont want to screw something up
                  '78E
                    There is a drain hose that connects to the rear of the tank and drain down behind the engine. There is also the vent for the middle drive which goes up to the top mount of the airbox.
                    • Titbit21
                      • Feb 2011
                      • 76
                      • Kent, Ohio
                      good looking nate. I almost thought that middle drive line was the gas one. thanks for the info. I just have to hook up the tank now and hear it fire. Hopefully lol
                      '78E
                        There's a hose/vent routing diagram in the back of the FSM that will help you identify all those hoses and where they go. It may be in the Clymer manual too, I haven't looked. If you don't have a manual, you really need one...
                        • Titbit21
                          • Feb 2011
                          • 76
                          • Kent, Ohio
                          Yeah i have two pdf manuals I got from a link on this site. I just didnt see a diagram in them. I have it all figured out now, from the help of you all. It seems like I shouldnt have a problem. I have only had the bike since begin of feb and i took the carbs and airbox out after i heard it fire for the first time. Just lost the mental picture i had when I did that.
                          '78E
                            That is why I take digital pictures, the mental ones never last at my age!!!
                            • Titbit21
                              • Feb 2011
                              • 76
                              • Kent, Ohio
                              any good threads on adjusting the air/fuel mixture? mine seem to not be getting enough gas. the plugs are dry and starting to turn white
                              '78E
