vacuum lines?
  • Titbit21
    • Feb 2011
    • 76
    • Kent, Ohio
    by the way, i took my first ride on my xs. YAY! just lacking throttle response and lack of power
    '78E
    • mack
      • 2411
      • Ontario, Canada
      Idle mixture screws
      The manual will tell you that they are set at the factory at 1 1/4 turns out. Probably should start at 1 1/2 and do 1/4 turns. BE VERY CAREFUL NOT TO SEAT THEM TOO TIGHTLY when you turn them in to the start point. They are very pointy and delicate and will break off in the holes. Hate to ask now that they are on, but did you bench sync the carbs first.
      mack
      79 XS 1100 SF Special
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      https://youtu.be/wB5Jfbp6SUc
      https://youtu.be/RaI3WYHSuWA
      Frankford, Ont, Canada
      613-398-6186
        Originally posted by Titbit21
        any good threads on adjusting the air/fuel mixture? mine seem to not be getting enough gas. the plugs are dry and starting to turn white
        This may help...
        • Titbit21
          • Feb 2011
          • 76
          • Kent, Ohio
          Well I had somebody clean and rebuild these carbs, he also said that they were benched synced. I decided to make a homemade sync tool will some tubing and fitting. Theres no need to do this blindly.
          '78E
