3rd project bike
    #46
    OK, I guess I have been sleeping through threads or something. What is the zip tie method?
      #47
      Yeah I am wondering what thy is too?
      Also talk to davinci, he has the shim library for shim trades.
      • Stepka
        • Apr 2011
        • 170
        • Shakopee, MN
        #48
        I zip tied the timing chain to the can gears than slightly lifted the cams.
        1981 xs1100 venturer... Finally runs
        Still has carb issues, but runs
        For all of your Amsoil needs go to www.mrguysoil.com
        • Rasputin
          • 3189
          • Lacombe, Alberta, Canada
          #49
          Originally posted by Stepka
          So I need x1-255 x3-265 x1-270 x1-280 x1-260 according to the chart, with all clearances at .05 +/- .01
          All I have that match your needs are
          1-255
          2-265
          1-270
          1-280
          I also have a spare (brand new) valve shim tool.
          If you can get the whole works from someone else it would be easier for you, but if you need these send a PM.
          2-79 XS1100 SF
          2-78 XS1100 E Best bike Ever
          • Stepka
            • Apr 2011
            • 170
            • Shakopee, MN
            #50
            1-255
            2-265
            1-270
            1-280
            Thanks, I am going to check with my local shop to see if they are willing to trade first.
              #51
              Whats the diff between tanks? I was told this bike is kinda rare is that true?
              It's a full gallon bigger than the other standard tanks. This of course increases the cruising range by the amount of extra gas carried.
              • Stepka
                • Apr 2011
                • 170
                • Shakopee, MN
                #52
                Well I ordered floats from mikes xs, along with other stuff. I also have shims on the way for my adjustment. I just hope everything is here before the weekend, so I can get it done before my weekend to work
                • Stepka
                  • Apr 2011
                  • 170
                  • Shakopee, MN
                  #53
                  I got the valves shimmed and everything back together. They are not perfect (within .002) but I couldn't get it any closer. I did a compression check (carbs off) after I finished and 1,3,4 are 125ish +/-2 and 2 is 80, dam!! I poured oil down the spark plus hole and compression increased, so it needs rings right?
                  The carbs are still out of the bike because I was waiting on my floats and shaft seals. I figured that after the whole deal with the busted float tower I would make them as close to new as possible. I do not want to be tearing into these again, except upgrades.
                  I hope to have it running this weekend or by Tuesday. Than all I have to worry about is freeing up my rear caliper piston and rebuilding that. I will still have to change all of the fluids before I take it out on the road for its first voyage.
                    #54
                    Get some miles one the bike before you worry about the compression. 9 out of 10 times the rings will free up in the first 500-1000 miles and be good as new.
                    • Stepka
                      • Apr 2011
                      • 170
                      • Shakopee, MN
                      #55
                      So..... put new floats in the carbs measured to .90 and these dam things are still overflowing. I have my tank off and I am using a plastic tank that hangs from above. Am I doing something wrong? Any help would b great! I am about to throw this whole *uckin bike in a junk yard.
                        • 8797
                        Try tapping on the bowls while they are filling. Sometimes the plastic floats drop too far when the bowls are empty and the needle valve gets cocked in the seat. There is a second float tang near the float post to prevent this from happening. Another cause would be aftermarket float bowl gaskets being just a tad too big and catching on the floats. If this is the case they can be trimmed down a bit. Third thing is the seat O-rings could be toast. Fourth thing could be debris getting caught in the needle/seat... you get the idea.
                        • Stepka
                          • Apr 2011
                          • 170
                          • Shakopee, MN
                          #57
                          I will try to tap on them. I got rebuild kits from georgefx on ebay so everything has been replaced and I have had these dam things apart 7 or 8 times already. I thought about debris from my plastic hanging tank so I put a filter and new lines this time. Would the constant fuel pressure from the hanging tank b to much for the needles to handle?
                            • 8797
                            I doubt it, you have gravity feed with the normal fuel tank too. Tapping the bowls while initially filling usually will do the trick.
                            • Stepka
                              • Apr 2011
                              • 170
                              • Shakopee, MN
                              #59
                              even without the bike running?
                              • Stepka
                                • Apr 2011
                                • 170
                                • Shakopee, MN
                                #60
                                Well I just beat the hell out of the carbs with a rubber hammer and they FINALLY stopped leaking like a bastard. Thanks for your help!! Tomorrow I hope to fire it up and see how she runs after all everything, wish me luck :-)
