There's not as much meat there as you might think; the sleeves have a flange at the top, and that's what you're seeing.
And I think Wiseco also offers a 1196 kit (or at least did at one time), but that is the limit. To go bigger than that, you're talking custom sleeves and boring the cylinder/cases. $$$...
Pete, you might want to check your rings for up/down orientation; while the top ring and the oil ring have the same profile either way, the second ring doesn't. This one has a taper face, and which way the taper is 'pointed' can make a big difference...
These usually have a 'dot' on one side that's supposed to face towards the head.
