Rear Wheel bearing LHS
  • James England
    • 3039
    • North of England
    #76
    Found it thanks. Unfortunately, on top of the cost of the bearing and shipping, they're asking for a $50 'web handling charge' to send this little part to the UK, so I'll not be buying one from these people. They come up as NOS on eBay from time to time, so I'll wait and get one of those next time one is available. The ones I've seen in the past have a grease-retaining seal. There's doesn't appear to be one here...?
      • 3373
      You might check with someone (bearing supplier) over there, NTN has to be around I would think, and have the supplier order it?
      As far as the left side grease seal, the seal is a separate part I believe. That part was available 3 years ago when I stocked up on an extra set of right side bearing, front wheel bearings, etc. Recently I heard Yamaha officially discontinued (correct me if I'm wrong) XS 1100 parts, at least what ones were still available. I'd think there would be some still out there in supply.
      Good luck, keep it greased well and regularly!
      2001 ZRX 1200
      1982 Seca 750
      1983 Nighthawk 550
      • DAVINCI
        • Jan 2011
        • 1048
        • Cedar Mountain, NC
        #78
        James England;
        I have one for you, new, not NOS. Got it last year, still in the box. I can mail it as a 'sample' or a 'gift' to save you the hassle. Make me an offer via PM.
        • cowboybob998
          • Mar 2009
          • 371
          • KC MO
          #79
          Ntn
          NTN is the bearing mfg. get ahold of them and they will have a list of supplyers in your area, if any that supply what they sell, and if the supplyer handels it right they can have it shiped direct from NTN if they dont have it in stock, you would still have to pay shiping what ever that might be. The bearing suplyer i bought mine from was right here in the area where i live and NTN told me who they were, and they did not have it in stock but they had it shipped direct from NTN to my house.
          1979 xs1100 f
          142 main, 45 pilot, Jardeen crosover 4/2, no air box
          floats @ 25.7
          1979 xs1100 F
          1978 gl 1000 goldwing
          1981 gl 1100 goldwing
          !986 venture royale 1300
          Just an ol long haired country boy, come to town to spend some egg money
          when ya get bucked off, get back on
          • James England
            • 3039
            • North of England
            #80
            How about this as an option? http://www.bearingboys.co.uk/NKIA590...aring_-19142-p
            OK, so it's an angular contact bearing with needle rollers and ball bearings. Would it do the job, do we think??
            • jwhughes3
              • 2798
              • Home of the Alamo
              #81
              the number matches
              The number part being the same maybe the same bearing from a different manufacturer?
              John
              '81 XS1100H - "Enterprise"
              • James England
                • 3039
                • North of England
                #82
                John
                No, it's the same manufacturer. The NA5904 is only a needle roller bearing. The one in my post above is a combination of needle rollers on one side and ball bearings on the other. All the dimensions are the same 20mmID, 37mmOD and 23mm width.... so it will physically fit.......but it is a different spec bearing in that it has the ball bearings and the needles. Somehow, I suspect it will probably do the trick
                • DAVINCI
                  • Jan 2011
                  • 1048
                  #83
                  The real trick on the NA5904 is that the inner ring moves freely. From the looks of that NKIA type, the inner ring is fixed at the ball bearing end. That might be a problem, when torquing up the axle it may bind.
                  • Lamric
                    XStremely XSive(Deceased)
                    • 410
                    • Kenley, Surrey, England
                    #84
                    Using that NKIA5904 bearing was discussed on the UK forum a couple of years ago - here
                    There are concerns that it's loading rating is lower.
                    Brian
                    XS1100 LG "Mr T", SG "ICBM" & FJ1200
                    Check out the XS Part Number Finder
                    Be not stingy in what costs nothing as courtesy, counsel and countenance.
                    • TomB
                      • 967
                      • Cumbria, UK
                      #85
                      Not sure if there is a little confusion here Brian, in the post you have linked I am saying if you used two Deep Groove Ball Race bearings like the XS750 has instead of the needle roller bearing that the XS11 uses, there would be load rating issues, this would be because the amount of space the XS11 has for a bearig would dictate a pair of very small DGBR bearings.
                      The needle roller combined with angular contact bearing I link to as an alternative to the original needle bearing has a very slightly lower rating but would probably last 2/3's the life of the original ....so thats 20 years instead of 30 years
                      Interesting that the NTN bearing is being made in batches though, great find lads, I'll contact our local bearing suppliers and ask them to look into it. Buying a batch for the UK stock might be worth looking into.
                      Tom
                        #86
                        And if properly cleaned and greased regularly it would probably go longer!
                        • Lamric
                          • 410
                          #87
                          Not sure if there is a little confusion here Brian...
                          Hi Tom,
                          OK, to clarify - I was replying to James England's query about the NKIA5904 bearing.
                          In the thread I linked to both Napier ("In conclusion, I cant see this bearing as a suitable replacement") and PeKemm ("I strictly decline the use of an NKIA 5904") expressed concerns about using the NKIA5904.
                          Brian
                          • TomB
                            • 967
                            • Cumbria, UK
                            #88
                            Ah yep, I see where you're coming from now.
                            The opinion expressed by PeKemm (and maybe Napier) seem to be opinions, which if based on experiences are very worthwhile.
                            What I was quoting were the load ratings from the bearing manufacturers own listings. I tend to believe the manufacturers info more than anyone elses, no disrespect meant lads
                            Tom
                            • James England
                              • 3039
                              • North of England
                              #89
                              I've found a supplier of the correct bearing here in the UK. £46 + 20% sales tax. Quite expensive but it's nice to know they can still be got hold of...........
                              • DAVINCI
                                • Jan 2011
                                • 1048
                                #90
                                Wow, what's that like $100 US? Even when we got the batches, we were able to get them for half that. You might want to try and source them here in the US and we can ship 'em over, definitely for less than that.
