Rear Wheel bearing LHS
  • rockman
    • 23
    • Inverell NSW Australia
    Originally posted by DAVINCI
    OK, then how about this...there's already a spacer there on the outside of the bearing, it pokes through the seal, right? How about installing one that's 6mm longer?
    That would work. Probably have to push the seal in to butt up against the bearing to keep it square but that shouldnt matter.
    • cywelchjr
      XS-XJ Super Guru(Deceased)
      • 4450
      • Sacramento, CA
      Why not just an extra spacer on the outside of that spacer? Just to take up the extra space? This might be a way to work around the lack of these unobtainium bearings (I guess we need to get to Pandora to get more unobtainium to make more of them from)
      • rockman
        • 23
        That'd work too, as long as it was outside the original spacer (as you suggest). On the inside it might interfere with the seal.
        I might buy one and see how it goes.
        • DAVINCI
          • Jan 2011
          • 1048
          • Cedar Mountain, NC
          If you do this, use one piece. You don't want that miniscule spacer falling out when you pull the axle. Or worse, falling inside behind the seal when you're installing the axle, that would be a real PITA
          • DAVINCI
            • Jan 2011
            • 1048
            What I meant was to replace the original spacer with one that's 6mm longer to make up the difference. The axle will square everything up.
            • cowboybob998
              • Mar 2009
              • 371
              • KC MO
              Dim. of bearing
              Will the part number give me the dim. of the bearing, there is a bearing wearhouse here in KC that may have the bearing, do yall have the inside and outside dim. of the bearing ?
              1979 xs1100 f
              142 main, 45 pilot, Jardeen crosover 4/2, no air box
              floats @ 25.7
              1979 xs1100 F
              1978 gl 1000 goldwing
              1981 gl 1100 goldwing
              !986 venture royale 1300
              Just an ol long haired country boy, come to town to spend some egg money
              when ya get bucked off, get back on
              • cowboybob998
                • Mar 2009
                • 371
                • KC MO
                XS 750 hub
                Yall may have allready tried this, will the hub out of a XS 750 work on the XS 1100 wheel because Bike Bandit shows that they have the bearings for the XS750 hub.
                1979 xs1100 f
                floats @ 25.7
                1979 xs1100 F
                • DAVINCI
                  • Jan 2011
                  • 1048
                  Just give them the part number, they have the cross references. If they don't, hang up the phone.
                  NTN NA5904
                  • DAVINCI
                    • Jan 2011
                    • 1048
                    Good call, the rear drive swaps out, so the wheel clutch hub may also swap out.
                    • cowboybob998
                      • Mar 2009
                      • 371
                      • KC MO
                      Xs850
                      The XS850 is the same bearing as the XS11, but they dont have it either.
                      1979 xs1100 f
                      floats @ 25.7
                      1979 xs1100 F
                      • cowboybob998
                        • Mar 2009
                        • 371
                        • KC MO
                        NTN NA5904
                        Called IBT bearing here in kansas city and they said that part number shows up as a bearing race, where can i find the dim. of this bearing ?
                        1979 xs1100 f
                        floats @ 25.7
                        1979 xs1100 F
                        • mxmikie
                          • Aug 2008
                          • 482
                          • Bouse az
                          A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
                          • cowboybob998
                            • Mar 2009
                            • 371
                            • KC MO
                            See what i can come up with
                            Thanks
                            1979 xs1100 f
                            floats @ 25.7
                            1979 xs1100 F
                            • cowboybob998
                              • Mar 2009
                              • 371
                              • KC MO
                              Thanks
                              looks like all i am going to do is what every one elece has allready done
                              IBT said they had ID and OD but it was only 9MM wide
                              1979 xs1100 f
                              floats @ 25.7
                              1979 xs1100 F
                              • cywelchjr
                                • 4450
                                • Sacramento, CA
                                What about epoxying the extra to it so it stays. I'd be worried about finding one with the protrusion like the original. Actually I'd really consider JBWelding it if I was going to do that, and probably see if I could order/get a new spacer first (nice clean surface). Failing that, get a used one and clean it really really good so I would still have the original for if going back to stock ever became possible or something. But of course, this is all academic right now.
